Hello Guest it is October 23, 2026, 04:12:18 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460848 times)
Re: Mach3 2010 Screenset - Now available
« Reply #330 on: March 18, 2015, 06:26:00 AM »
So, save the M5 and M6 eliminate N284-N288...?
« Reply #331 on: March 18, 2015, 06:31:38 AM »
Yes, you don't need N284, N286 or N288.
With the auto zero during the toolchange, you also won't need N294, which is a tool length offset.
« Reply #332 on: March 18, 2015, 07:59:05 PM »
Anyone know how to modify that information in the post?
I'm using MPFAN.pst in MasterCam.. I made some modifications but I'm not 100% on the sections you've identified.
N278 G1 Z.203 F30.
N280 G0 Z.25
N282 M5                 -- Spindle stop
N284 G91 G28 Z0.   -- not sure why this is here
N286 A0.                -- not sure why this is here
N288 M01               -- temporary stop
N290 T235 M6        -- Tool change
N292 G0 G90 G54 X1.875 Y6.7025 A0. S12224 M3
N294 G43 H235 Z.25
N296 Z.2
Code: [Select]
# General Output Settings
maxfeedpm    : 500   #SET_BY_MD Limit for feed in inch/min
ltol_m       : 0.05  #Length tolerance for arccheck, metric
vtol_m       : 0.0025#System tolerance, metric
maxfeedpm_m  : 10000 #SET_BY_MD Limit for feed in mm/min
force_wcs    : yes$  #Force WCS output at every toolchange?
stagetool    : 0     #SET_BY_CD 0 = Do not pre-stage tools, 1 = Stage tools
stagetltype  : 0     #0 = Do not stage 1st tool **modified 3/18/15 was 1
                     #1 = Stage 1st tool at last tool change
                     #2 = Stage 1st tool at end of file (peof)
use_gear     : 0     #Output gear selection code, 0=no, 1=yes
min_speed    : 50    #SET_BY_MD Minimum spindle speed
progname$    : 1     #Use uppercase for program name (sprogname)
prog_stop    : 0     #Program stop at toolchange: 0=None, 1=M01, 2 = M00 **modified 3/18/15 was 1
tool_info    : 2     #Output tooltable information?
                     #0 = Off - Do not output any tool comments or tooltable
                     #1 = Tool comments only
                     #2 = Tooltable in header - no tool comments at T/C
                     #3 = Tooltable in header - with tool comments at T/C
tlchg_home   : no$   #Zero return X and Y axis prior to tool change?
« Last Edit: March 18, 2015, 08:05:00 PM by Adam_M »
« Reply #333 on: March 18, 2015, 08:12:52 PM »
Never used MC, but if I had to guess, I'd say to change "force_wcs" to no.
« Reply #334 on: March 21, 2015, 08:00:19 AM »
Thanks Gerry, that got me close enough to resolve the issue I was having.
Adam,
« Reply #335 on: March 31, 2015, 06:50:07 AM »
Hello Gerry,
What do you think, will your nice screenset with the large toolpath work well on an old laptop, IBM Thinkpad T42 with 1.6 GHz Pentium Mobile and ATI Radeon 9000 64 MB graphics?
Paul.
« Reply #336 on: March 31, 2015, 07:00:02 AM »
I have no idea.
In 4 years, I've had 2 or 3 users (that I'm aware of) that had PC's where the larger toolpath caused mach3 to run poorly.
If you purchase it and it doesn't work, I'll give you a refund.
« Reply #337 on: March 31, 2015, 07:02:25 AM »
Thanks Gerry, then I'll give it a try.
« Reply #338 on: April 10, 2015, 09:54:36 AM »
Hi Gerry,
Just built my CNC and am getting it zeroed in. Love you screenset.
Probing works great.
How do I get to axix calibration from your screenset. As it is now I have to switch to the standard set in order to calibrate.
George M
« Reply #339 on: April 10, 2015, 10:10:39 AM »
How do I get to axis calibration from your screenset. As it is now I have to switch to the standard set in order to calibrate.
That's how you have to do it. Since you should only have to use it one time, I didn't add it to the screenset. And it only takes 5 seconds to change back.
