Hello Guest it is October 23, 2026, 04:10:05 PM
Author Topic: Mach3 2010 Screenset - Now available  (Read 1460802 times)
Re: Mach3 2010 Screenset - Now available
« Reply #140 on: March 21, 2013, 10:31:06 AM »
No problems. If you read my 2010 manual, it has a section on how to modify the homing scripts.
Offline Bloy
  •  158 158
« Reply #141 on: March 21, 2013, 10:33:12 AM »
I'm STILL reading it.... ;)
I can't find the code notes on the refcombination( 19 ) yet.  What would that look like?
Or where would I look to view it.?
I'd also like to insert them(the code notes) like you have for your DoButtons.
john
« Last Edit: March 21, 2013, 10:44:30 AM by Bloy »
« Reply #142 on: March 21, 2013, 10:45:35 AM »
Page 17 of the manual.
http://home.comcast.net/~cncwoodworker/downloads/mach3/2010%20Manual.pdf
RefCombination(19) would home the X, Y, and B axes together
Offline Bloy
  •  158 158
« Reply #143 on: March 21, 2013, 10:53:17 AM »
ah..... now I remember Art explaining the number combinations.   I might, probably, have a file somewhere with his notes.  I've got a lot of catching up to do.....
Offline Bloy
  •  158 158
« Reply #144 on: March 22, 2013, 08:20:13 AM »
Hi Gerry,
 After getting up this morning I realized how idiotic my posts were from yesterday.  They were all based on the old acronym RTFM. ::)
Honestly, I wonder if I am losing it faster than I am gaining.   It could be a touch of senility sneaking in complicated with the influx of radon gas saturating the atmosphere here in my basement.
Sorry...
« Last Edit: March 22, 2013, 08:27:17 AM by Bloy »
« Reply #145 on: March 22, 2013, 09:45:59 AM »
No problem at all.
90% of the questions I get can be answered with RTFM. ;)
Thanks for the kind words, btw.
« Reply #146 on: March 22, 2013, 09:47:58 AM »
 ;D
« Reply #147 on: May 13, 2013, 04:57:42 AM »
 Hello !
 There is one feature in Screenset 2010 that I'm not able to understand:
 - What is the purpose of 'DE-Ref all axis' ? Why would I want to dereference all my axis ?
 - I'm a registered user of SC2010... Will I receive a mail notification if a new release is made available ?
 Thank you !
« Reply #148 on: May 13, 2013, 08:51:56 AM »
The standard screen has a De-Ref button, so I added it. I have no idea what you'd use it for.
There most likely won't be any more updates. If there are, I send them out to all users.
« Reply #149 on: May 13, 2013, 09:10:25 AM »
 Thanks Gerry.
 I have made some research about this Deref button (Which is in the standard screen, you're right) and nothing really clear !
 I'm having another question, which are related to Mach3 and/or Screenset 2010, I don't know...
 I'd like to use Output to manage some LEDs...
 For example:
 LED on when click START (And START has been 'accepted' of course)
 LED off when click STOP, etc...
 The idea is to hook some external LED which are available on a command pulpit to have better overview of the process...
 Two problems:
 When cliking the Start button, it calls an 'internal function' which is called start.  I don't know how to modify it to add this feature !
 Some others button calls a script, for example: M889.m1s (Simple auto zero) or M885.m1s (REF X)
 I'd like to activate an output (To a LED)
 LED should be on until the script M885 has been finished or cancelled.
Example:
ActivateSignal(OUTPUT7)
DoButton(22)
'Code "G53 G0 X1"
'While IsMoving()
'Wend
 DeActivateSignal(OUTPUT7)
 Doesn't work ;-(
 IK don't know exactly how to hook output management into Mach3...
 Could someone Help ?   Hope I'm clear enough !
 Thank you !
