Hello Guest it is October 20, 2026, 09:40:40 PM
Author Topic: NFS Turn Wizard  (Read 968355 times)
Re: NFS Turn Wizard
« Reply #140 on: May 08, 2013, 09:14:35 AM »
Ron these are the same ones that i have been using but cant put them together like Facing and turning. One of the moderators helped me get License installed and helped me a hole lot but still cant get to work like i see in your first post
Thanks again for your help
Re: NFS Turn Wizard
« Reply #141 on: May 08, 2013, 06:39:35 PM »
You do not have the NFSturn wizards installed. You have only the free ones.
Go to the top entry in this thread and get the .zip file. Un pack it in the Mach3 folder, so that the NFSturn folder is under Turnaddons. The restart mach and open the wizard list and you should see NFSturn in the list.
Re: NFS Turn Wizard
« Reply #142 on: May 09, 2013, 08:13:44 AM »
Ron we are getting there i now have something were are close am getting this screen?
Re: NFS Turn Wizard
« Reply #143 on: May 09, 2013, 11:24:48 AM »
You do not have the wizard installed correctly. The Folder name must have the 008 removed. The NFSturn.set file should be in the folder NFSturn There are several other files in that folder.
Re: NFS Turn Wizard
« Reply #144 on: May 09, 2013, 12:26:49 PM »
Can you see what is going on hear?
Re: NFS Turn Wizard
« Reply #145 on: May 09, 2013, 12:30:44 PM »
screen shot 2#
Re: NFS Turn Wizard
« Reply #146 on: May 09, 2013, 12:39:35 PM »
3 shot
Re: NFS Turn Wizard
« Reply #147 on: May 09, 2013, 01:36:10 PM »
In the first folder the folder called NFSturn008 should have the 008 removed, make it just NFStrun
The second folder shuold not have the .zip file in it. Its part of the wizard called Turning
The contents of the third folder should be in the NFSturn folder that you renamed from NFSturn008
Re: NFS Turn Wizard
« Reply #148 on: May 10, 2013, 01:48:55 PM »
Ron i have got it up and working sorry for all the miss i just didn't know that much about working with a File a friend got me going.
Thanks again for working with this OLD Man
Re: NFS Turn Wizard
« Reply #149 on: August 18, 2013, 03:57:38 PM »
Hi Ron,
Any more thoughts as to when or if an OD Radius operation might be coming to NFS Turn Wizard? Just my yearly pestering. Sure would be nice!
Doug
