Hello Guest it is October 21, 2026, 04:04:49 AM
Author Topic: NFS Turn Wizard  (Read 968412 times)
Re: NFS Turn Wizard
« Reply #150 on: October 03, 2013, 03:12:33 PM »
Not sure if this is the correct place to ask this?  I need to make a couple V-belt pulleys (sheaves if you prefer), one with a 60 degree groove, the other 62 degree.  Does the NFS Turn Wizard package have something to handle that?  I'd rather not grind a form tool for each or hand code it and would like to use a DCMT insert (55 deg) and peck/nibble away at it similar to the OD Groove wizard's process.
 Also interested in an ID Parabola wizard (for model engine venturis).
Thanks in advance for any input.
Milton from Tennessee ya'll.
Re: NFS Turn Wizard
« Reply #151 on: October 03, 2013, 03:30:10 PM »
Why not use Dolphin, should be easy enough in that ;)
Re: NFS Turn Wizard
« Reply #152 on: October 03, 2013, 03:53:56 PM »
You're very right Robin...it should be easy enough but it was a few months ago that I last worked with Dolphin.  Apparently everything I learned has turned to a mushy slime & has oozed out of my ears since then.  It's downright frustrating this getting old thing.
Besides, m'Dolphin mentor's done switched over to BoobCat or sumthin'. ::)
(Thanks for the prod...I should get some time this weekend to give it another try.  1st try was a no-go)
Re: NFS Turn Wizard
« Reply #153 on: October 03, 2013, 04:07:24 PM »
LOL I reckon I will still remember how to use Dolphin, so if you need a helping hand just email me and I will try.
I wont be able to help much with your stone age  units as my brain doesnt work that way, well except when I am talking Fathoms and not a Fisherman any more, so thats not often ;D
Re: NFS Turn Wizard
« Reply #154 on: October 03, 2013, 09:12:52 PM »
Thanks!  I'm sure I'll have questions and yes, I'm still using ye olde inch measurements.  However, I am proud to report that I have officially switched over to diameter mode! ;D
Re: NFS Turn Wizard
« Reply #155 on: October 03, 2013, 09:19:26 PM »
I think the wizard might work. It does allow tapers, and can start and end either at the large or mall diameter. it would take a few experiments to see. Ill try it when I  get a chance
Re: NFS Turn Wizard
« Reply #156 on: October 03, 2013, 10:18:54 PM »
Try Lazyturn as that provides for a 55 deg tool.
Re: NFS Turn Wizard
« Reply #157 on: October 04, 2013, 02:18:15 AM »
Milton, I tried with Dolphin last night, took me about 5 mins to do my drawing and save as a DXF, open in Dolphin CAD, choose my shape, import to CAM and pick toolpath and do a rough and finish. It is quite easy once you get into the way of it :)
Re: NFS Turn Wizard
« Reply #158 on: October 04, 2013, 08:34:06 AM »
Sure, when you're Hood.;)  I had the .dxf imported and was working on the paths but screwed up somehow and got frustrated.  It'll get there when I have time to work with it more than a few minutes at a time.
Turns out I actually have a day off from my real job today so I'm going to give it a shot later if I ever get past the mountain of honey-do's that's in front of me.
ps:  Ron, Thanks for your input and I apologize for the thread jack with the Dolphin talk.  I am a little surprised nobody's asked for a V-groove wiz though...I must be the only cheapskate that wants to make his own pulleys instead of just buying them.;)
Re: NFS Turn Wizard
« Reply #159 on: October 04, 2013, 07:04:18 PM »
A sheave(pulley) Wizard would not be hard to do. Nor would a programable sub.
Just a thought, (;-) TP
