Hello Guest it is October 21, 2026, 04:43:53 PM
Author Topic: NFS Turn Wizard  (Read 968592 times)
Re: NFS Turn Wizard
« Reply #110 on: July 18, 2012, 05:29:20 AM »
Ron,
Have you had a chance to look at the drill cycle coding?
Re: NFS Turn Wizard
« Reply #111 on: July 18, 2012, 05:58:39 AM »
That is an internal Mach error, not a wizard error. Does it happen every time you try to start the wizard? Does it happen when starting any other wizard?
How about if you start the machine with a mill profile and try to start a wizard?
Re: NFS Turn Wizard
« Reply #112 on: July 18, 2012, 06:04:53 AM »
Ron it only happens when I try to start the NFS turn wizard, i have started the standard turn wizards and the NFS wizards in the mill profile.
Will
Re: NFS Turn Wizard
« Reply #113 on: July 18, 2012, 06:08:01 AM »
OK, Ill try to get Brian to look at it. There is really nothing unusual about the NFSturn wizard that should trigger an error.
Re: NFS Turn Wizard
« Reply #114 on: August 18, 2012, 06:51:54 PM »
Great wizard, Ron!  Will you be adding an OD Radius operation in the near future. It would be a great help
Also is there a way to call this wizard from an OEM code?
« Last Edit: August 18, 2012, 06:54:11 PM by Steambuilder »
Re: NFS Turn Wizard
« Reply #115 on: August 18, 2012, 08:14:00 PM »
Im looking for a 'round to it' I have been working a lot on the new mach4 mill wizards, getting close to done now. I will get it, hopefully soon.
Re: NFS Turn Wizard
« Reply #116 on: August 29, 2012, 03:49:44 PM »
Is there a way to call the NFSTurn Wizard from an OEM code? I tried DoOemCode (321) but that doesn't seem to do anything. I'm just tired of having to make all the clicks to get there.
Thanks for any help
Doug
Re: NFS Turn Wizard
« Reply #117 on: August 29, 2012, 05:38:04 PM »
no, not that I am aware of.
It is interesting that through most of the development of the turn wizards I planned to make them a screen set instead of a wizard. That way they would come up directly with mach. At the end we decided to go to a wizard format for reasons related to the license and distribution.
Re: NFS Turn Wizard
« Reply #118 on: October 09, 2012, 12:48:57 PM »
Make a Screen Button and use this code
LoadWizard(" NFSturn ")
Note: To call the wizards selection page it is
DoOemButton(321)
Just a thought, (;-) TP
« Last Edit: October 09, 2012, 12:50:34 PM by BR549 »
Re: NFS Turn Wizard
« Reply #119 on: October 09, 2012, 02:12:51 PM »
Thanks TP! That helps a lot.  Now if I can figure out how to call this from my Logitech controller I'll be in business. I like to keep mouse clicks to a minimum.
Thanks Again
Doug
