Hello Guest it is October 22, 2026, 08:47:38 PM
Author Topic: NFS Turn Wizard  (Read 968856 times)
Re: NFS Turn Wizard
« Reply #100 on: June 07, 2012, 06:24:42 PM »
It sounds like you have something wrong with your threading setup. The wizard simply writes a line of code, then its up to Mach to run it.
Threading only works for a licensed version of mach- the demo will not thread.
Threading requires an index pulse, have you checked it on the diagnostics page. Note you need to rotate the spindle by hand because the LED only flashes on briefly once per rev.
There are some other threading suggestions in the general mach part of this forum.
Offline Bengt
  •  54 54
    • Private CNC site
Re: NFS Turn Wizard
« Reply #101 on: June 08, 2012, 03:20:50 AM »
One IMPORTANT request, there is no manual jogging via keyboard so I really want to push on this upgrade asap to have this wizard fully functional.
Hi Ron,
Have you had a chance to look at this?
Bengt
Bengt
Re: NFS Turn Wizard
« Reply #102 on: July 07, 2012, 08:10:14 AM »
Hi Ron,
Reguarding Drill:
- Is the Dwell time just a default to a value of 1 or can one set it to different value somewhere?
- Seems like for Zend  values of less than -1 the Peck and Peck Retract do not provide the correct code for the cycles.
Re: NFS Turn Wizard
« Reply #103 on: July 07, 2012, 11:33:19 AM »
yes, the 1 sec dwell is built in to the program. I dont like to add to many DROs since it makes the input screens more complicated.
I dont see the problem with Zend values. Can yu give me an example?
Re: NFS Turn Wizard
« Reply #104 on: July 07, 2012, 11:47:10 AM »
I have fixed a couple issues, see topic 1 for the new zip file
Offline Bengt
  •  54 54
    • Private CNC site
Re: NFS Turn Wizard
« Reply #105 on: July 07, 2012, 12:42:07 PM »
Hi Ron,
Thanks for the update, will try to run this tomorrow on my lathe so I can report back.
Bengt
Bengt
Re: NFS Turn Wizard
« Reply #106 on: July 08, 2012, 04:48:16 AM »
Ron,
Attached is an example.
Re: NFS Turn Wizard
« Reply #107 on: July 16, 2012, 11:36:36 PM »
Hi Ron
I am having trouble getting the wizard to work, I have taken the version number off the zipped file and unzipped it in turn addons, and i get a message that something is misssing, it also dosent show the author etc in the list?
I have the licence file in c/mach3 and the other NFS wizards are working
Will
Re: NFS Turn Wizard
« Reply #108 on: July 17, 2012, 06:33:18 AM »
The folder structure should be  as follows.
TurnAddons
    NFSturn
        Bitmaps
          (many bit map files)
        ChangeLog.txt
        GcodeEnd.tap
        GcodeStart.tap
        Init.m1s
        NFSturn.set
        NFSturn.set.def
        Threads.txt
If this doesnt help please tell me what the error message says is missing.
Re: NFS Turn Wizard
« Reply #109 on: July 17, 2012, 10:24:11 PM »
Hi Ron
I checked and all the files are there, the message I got today when I tried to open the wizards was,
Error Triggered  ART Code 8877
Attempt Recovery
Yes - Nothing Happens
No - Mach closes and wants to send an error report.
Will
