Hello Guest it is October 23, 2026, 10:53:02 AM
Author Topic: NFS Turn Wizard  (Read 968975 times)
Re: NFS Turn Wizard
« Reply #130 on: April 03, 2013, 01:59:20 PM »
Hello Ron,
Thankyou for your reply concerning thread pitch Dro , I will look for it in the future.
Would you have any suggestions to why the feed Dro will not display work and reads 0 all the time. Is there somewhere I can
Go to look to see if this Dro is activated or not.
Thanks again for your help and time put into replying.
Regards Allan
Re: NFS Turn Wizard
« Reply #131 on: April 17, 2013, 03:16:30 PM »
I am not sure if making an edit to the first topic sends a message to guys watching this note, but I put a new version in topic 1 with an update for the metric threads. You now have a DRO to enter both TPI and pitch. One of them must be zero, enter a value in the one you want to use.
I did this in my hotel while traveling between Cabin Fever and NAMES ME shows, so obviously I have not tested it on a real machine, but the code looks correct. I cannot check the feed DRO until I get back to my shop.
Offline tantan
  •  130 130
Re: NFS Turn Wizard
« Reply #132 on: April 18, 2013, 01:47:55 PM »
hi ron,
great wizard. but i have one request.
if i fill in the OD threading DRO's like: z-start = -10 and z-end = 1 your wizard generates an alarm that says that z-start must be greater than z-end. is it possible not to check for this like the "simple threading wizard" does. because it depends on how the user would like to cut the thread. i have an EmcoTurn 120 and on my machine it is much more easier to cut the thread from left to right. simply leave the check if z end is smaller than z-start will do the trick
tnx TanTan
Re: NFS Turn Wizard
« Reply #133 on: May 07, 2013, 02:39:23 PM »
Can i get this wizard the turn wizard that i saw on your first post i have the ad don licence or do i need something Else ?
Re: NFS Turn Wizard
« Reply #134 on: May 07, 2013, 03:57:43 PM »
If you have the Newfangled Wizard license, which cost $50, then you are all set for the NFStrun and Mill wizards.
Re: NFS Turn Wizard
« Reply #135 on: May 07, 2013, 04:44:49 PM »
I have the (MACH3 Addons ) Now do i need The (Newfangled Solutions Mill Wizards) to beable to use the new NFStrun ?
Re: NFS Turn Wizard
« Reply #136 on: May 07, 2013, 06:22:36 PM »
No, MACH3 Addons is the same thing as the Newfangled Wizards. You are all set. Start up the NFSturn and if your license is properly installed it will say 'Licensed version' on the first screen
Re: NFS Turn Wizard
« Reply #137 on: May 07, 2013, 07:35:07 PM »
Ron all i see when i open turn is this screen shot
Re: NFS Turn Wizard
« Reply #138 on: May 07, 2013, 09:34:19 PM »
you have not selected the wizard, you are at the main screen. Click the Wizards menu then look for NFSturn in the list of wizards.
Re: NFS Turn Wizard
« Reply #139 on: May 08, 2013, 09:05:48 AM »
This is the problem [/img]
