Hello Guest it is October 21, 2026, 12:04:02 AM
Author Topic: Cylinder Heads  (Read 778710 times)
Re: Cylinder Heads
« Reply #110 on: October 26, 2010, 06:37:42 PM »
Hello All!
Spent the afternoon pressing in all the valve cages. I made s simple drive dool slightly smaller than the ID og the cage and pressed them in a drill press. I like the fact that the press fit does not need to be very tight because the cage cant be shot out by the compression of the cylinder.
I also started to make some valves. These wont go as fast as the cages.
Stand By!
Re: Cylinder Heads
« Reply #111 on: October 26, 2010, 07:19:00 PM »
Just some really impressive work there, Steve-
Re: Cylinder Heads
« Reply #112 on: October 26, 2010, 07:56:28 PM »
Looking good Steve. Look forward to seeing it put together.
Re: Cylinder Heads
« Reply #113 on: November 01, 2010, 06:51:36 PM »
Hello all!
All 40 of the valve blanks are completed. They take forever but it will someday be worth it.
To cut the slots I used my ER11 collets. I was able to put the valves in backward and slot the stem for the E-clips. I have an insert holder and a .020 slotting tool. Makes it easy to have a nice sharp tool because I stink at grinding tool bits.
Then I made a few test pieces. I chose not to reduce the size of the stem at the head so I could hold the valve real close for rigidity. I took a light cut accross the face. I want the valves flush in the head and the hole for the valve cage is .250 so I reduced the OD of the valve down to .245.
Then I cut the valve angle into the back surface.
So now you all know what I'll be doing tomorrow!!
Re: Cylinder Heads
« Reply #114 on: November 01, 2010, 07:12:31 PM »
Posting more pics, I hope! It's looking great. Thanks for keeping us in the loop.
Re: Cylinder Heads
« Reply #115 on: November 02, 2010, 06:27:47 PM »
You got your wish Sam!!
Hello All!
Finished all the valves tonight. Everything went according to plan.
Had a little extra time so I got a jump on the rocker studs.
Re: Cylinder Heads
« Reply #116 on: November 03, 2010, 11:24:01 AM »
I've really enjoyed watching this. I have a question, what spark plugs do you use for an engine like this?
sully
Re: Cylinder Heads
« Reply #117 on: November 03, 2010, 05:36:48 PM »
I will be making my own. They will have a 8-40 thread. Say some prayers.
Re: Cylinder Heads
« Reply #118 on: November 06, 2010, 05:53:22 PM »
Hello All!
I finished all the bottoms and all that is left is to mill the hex on the shaft so they can be installed. For that I just used the rotory table in the mill with a collet holder in the center of the table.  I have made 120 pieces in the last 2 weeks and now I have to make the valve spring retainers, 40 of them.
Re: Cylinder Heads
« Reply #119 on: November 06, 2010, 10:26:27 PM »
Enjoy seeing this come to life. Maybe some of your enthusiasm will rub off on me.
