Hello Guest it is October 21, 2026, 03:29:21 AM
Author Topic: Cylinder Heads  (Read 778891 times)
Re: Cylinder Heads
« Reply #280 on: August 22, 2011, 09:15:12 PM »
Is that a Gas can and a quart of Oil I see?
So when do we see Fire coming out of those pretty pipes?
What material did you use for the tubes and how did you shape them?
« Last Edit: August 22, 2011, 09:17:46 PM by Ya-Nvr-No »
Re: Cylinder Heads
« Reply #281 on: August 22, 2011, 09:23:33 PM »
If you are going to race that at Daytona next year you wiil need a set of 180 deg crossover pipes(;-)
Re: Cylinder Heads
« Reply #282 on: August 23, 2011, 03:24:20 PM »
The pipes are stainless steel. They were bent in a home made bender made by my pal Ron.
Re: Cylinder Heads
« Reply #283 on: August 23, 2011, 04:05:18 PM »
Real nice work, Steve, and from Ron as well-
  •  9,374 9,374
Re: Cylinder Heads
« Reply #284 on: August 24, 2011, 12:36:42 AM »
Nice work Steve - I reckon Boyd Coddington would have been proud to see pipes like that.
Re: Cylinder Heads
« Reply #285 on: August 24, 2011, 04:42:36 AM »
Have enjoyed the thread, thanks for the time and effort in sharing it all.
Re: Cylinder Heads
« Reply #286 on: August 24, 2011, 03:58:11 PM »
Glad you enjoy the updates. Hopefully there will be some video soon.
Re: Cylinder Heads
« Reply #287 on: August 24, 2011, 04:21:13 PM »
Assume showing it running , but where is the tach?? ;D
Heck throw in the dynometer..... :) ;)
Re: Cylinder Heads
« Reply #288 on: August 24, 2011, 04:55:19 PM »
NOW PLEASE ;D ;D ;D
JEFF
Re: Cylinder Heads
« Reply #289 on: August 25, 2011, 04:04:37 PM »
Yesterday I made the second half of the boot mold. After being sent home from work because of a small fire and power failure in the refinery, I made the core pins and made a test run.
I could have mixed the material better. The color is not good. I think I pressed a little harder than I should have also. The result was great. I have made 5 boots now and they look better. I tried to color one with black pigment but after 1/2 hour in the mold it was still soft. Grey will look just fine.
They look a little big but so do the plugs so it is something i will learn to accept. I don't think I want to go any smaller.
