Hello Guest it is October 21, 2026, 04:22:13 AM
Author Topic: Cylinder Heads  (Read 778955 times)
Re: Cylinder Heads
« Reply #220 on: May 30, 2011, 12:13:49 PM »
Went ahead and put some valves in 2 of the heads. I found that about half of the valves had the groove cut to big and the clip would not seat into the retainer. I chucked them back into the collet and cut the grooves .002 deeper and they went together like they should.
Then I decided to install the rocker studs more perminent. They had been screwed in finger tight forever.
With the heads being done I nailed down my finished push rod length. I only had enough rod to make 12 rods but that will be fixed tomorrow.
Then a set of rockers were assembled and put into place. Nothing is adjusted with the camshaft not properly timed yet.
I need to get on the distributor soon but I have not had the drive to work in the garage lately
Re: Cylinder Heads
« Reply #221 on: May 30, 2011, 04:08:35 PM »
Steve you can slow down now you have already missed INDY for this year (;-)
Re: Cylinder Heads
« Reply #222 on: May 30, 2011, 04:22:24 PM »
Yeah but there is always next year!!
Re: Cylinder Heads
« Reply #223 on: June 06, 2011, 06:23:01 PM »
The electrodes were made .002 larger than the hole in the cap. The wire gets threaded thru from the bottom and the brass is pressed into the cap.
Re: Cylinder Heads
« Reply #224 on: June 07, 2011, 08:43:54 PM »
What material is the Distributor cap made of? Looks like you will be able to see the spark when it fires. That should be interesting.
I must have missed when you polished and engraved the rocker covers. Looking nice.
Looks like your close to filling it with Torco?
Re: Cylinder Heads
« Reply #225 on: June 09, 2011, 03:30:21 PM »
Re: Cylinder Heads
« Reply #226 on: June 10, 2011, 12:36:32 PM »
HEY STEVE have you gotten those heads NASCAR approved yet ???  IF you need them flow tested I am your man ;-)
LOOKIN GOOD DUDE, (;-)TP
« Last Edit: June 10, 2011, 12:38:12 PM by BR549 »
Re: Cylinder Heads
« Reply #227 on: June 19, 2011, 01:14:58 PM »
Scratch water pump off the list. Instead of tapping a hole to thread a fitting in the pump, I decided to recycle the fitting in the water neck and just solder it in. I had to sand blast the paint off and the rest was easy.
Still going to need some paint but the pump is 100%
Re: Cylinder Heads
« Reply #228 on: June 20, 2011, 12:18:20 AM »
Steve are you about ready to build a CNC cam grinder for those puppies ?
Re: Cylinder Heads
« Reply #229 on: June 20, 2011, 04:55:27 PM »
Nope!  In the time it would take me to write the code I could make 2 by hand.
