Hello Guest it is October 21, 2026, 12:03:14 AM
Author Topic: Cylinder Heads  (Read 778695 times)
Re: Cylinder Heads
« Reply #240 on: July 03, 2011, 12:30:52 PM »
(shame you can't sell the ability as well as the plans).
For an extra dollar i could send some kind of certificate! Haahahaha!!
Re: Cylinder Heads
« Reply #241 on: July 03, 2011, 01:40:43 PM »
IF I could BUY that ability for a dollar I would order a HUNDRED DOLLARS worth. (;-)
Re: Cylinder Heads
« Reply #242 on: July 03, 2011, 04:28:57 PM »
So, basically, the same thing as most trade schools do.  ;D
Re: Cylinder Heads
« Reply #243 on: July 03, 2011, 06:46:59 PM »
Scratch fuel tank off the list!
Work was cancelled for the day so i made the 2 end caps for the fuel tank. They are just 2 slugs of brass but if you want to increase the capacity of the tank the ends could be bored out.
After polishing the tubing the holes were drilled for the filler neck and outlet fitting. I didn't call out the holes in the drawings because I felt everybody has a personal preference as to where the fittings go. The fittings were then soldered in from the inside.
I cant remember where i saw this but the inside wall gets fluxed and a piece of solder is wrapped around the inside of the tank. The end cap is fluxed and installed. The prepared end is set on the table and a torch heats until the solder melts and bonds that end.
The same process is used on the other end and then the tank gets soldered to the mount bar. I rubbed it a little on the buffer. There is alot more buffing to do but you get the idea.
Offline spunk
  •  56 56
Re: Cylinder Heads
« Reply #244 on: July 04, 2011, 01:07:05 PM »
do i see a fan in the background?
Re: Cylinder Heads
« Reply #245 on: July 04, 2011, 01:18:24 PM »
Yep!  I didn't like it and plan to make another one.
Offline spunk
  •  56 56
Re: Cylinder Heads
« Reply #246 on: July 05, 2011, 02:10:06 PM »
A little bit more fancy then?
Re: Cylinder Heads
« Reply #247 on: July 05, 2011, 03:14:39 PM »
How fancy can you get with a fan?
andrewm
Re: Cylinder Heads
« Reply #248 on: July 05, 2011, 03:44:54 PM »
That looks nice, awesome work! :)
Re: Cylinder Heads
« Reply #249 on: July 05, 2011, 07:38:31 PM »
Thank you
