Hello Guest it is October 21, 2026, 06:27:06 AM
Author Topic: Cylinder Heads  (Read 779073 times)
Re: Cylinder Heads
« Reply #80 on: August 15, 2010, 03:08:57 PM »
Hello All!
Had the chance to make some cylinder liners today.
One down, one to go.
Re: Cylinder Heads
« Reply #81 on: August 15, 2010, 06:29:34 PM »
Maybe you can have the liners anodized...
Re: Cylinder Heads
« Reply #82 on: August 15, 2010, 07:41:53 PM »
I thought the liners would be steel, no?
Re: Cylinder Heads
« Reply #83 on: August 15, 2010, 08:14:30 PM »
Yes, steel liners, aluminum pistons, cast iron rings.
Re: Cylinder Heads
« Reply #84 on: August 21, 2010, 04:01:00 PM »
Hello All!
Found some garage time so i sprang into action. Setup the block and indicated it in.
Took a cut across the deck surface to get the liners down to the deck height.
Then I ran a boring bar thru the cylinders to bring the holes to size. and called that done.
Then I made the 32 lifter bushings for both blocks.
Tomorrow the other block will get finished.
Re: Cylinder Heads
« Reply #85 on: August 21, 2010, 04:39:44 PM »
Lookin real good. I see your makin one for me too.  ;D
If you made a thousand, you wouldn' t have enough.
Went to a small engine show last week, and a guy there showed me how he does the cams in a lathe. Very interesting.
Thanks for sharing.
Ed VanEss
Re: Cylinder Heads
« Reply #86 on: August 21, 2010, 05:13:19 PM »
What show did you go to? Was it in southern Ohio?
Re: Cylinder Heads
« Reply #87 on: August 21, 2010, 08:23:37 PM »
Was the Chillton Steam engine show in Wisconsin.
Ed VanEss
Re: Cylinder Heads
« Reply #88 on: August 21, 2010, 08:53:45 PM »
Hey Ed, get in line, i asked before you!
Ok Steve, so who is it going to be, Ed, me, or the pretty gal on the corner .......... >:D
Offline N4NV
  •  398 398
Re: Cylinder Heads
« Reply #89 on: August 21, 2010, 11:09:59 PM »
How did you keep the cylinder liners from spinning during the machining?
Vince
