Hello Guest it is October 21, 2026, 12:03:54 AM
Author Topic: Cylinder Heads  (Read 778708 times)
  •  9,374 9,374
Re: Cylinder Heads
« Reply #260 on: July 26, 2011, 12:53:17 AM »
Hi Steve,
I think Sam and I both agree that everything aluminium should be anodized.  ;D
(For those who have not done it before you can purchase complete kits of chemicals and dyes together with easy to follow instructions and stunning colours and effects are possible. Obviously care is needed handling and storing the chemicals so you really need a working area secure from children, pets etc).
Re: Cylinder Heads
« Reply #261 on: July 26, 2011, 08:04:23 PM »
Didn't like the fan so I made another
Re: Cylinder Heads
« Reply #262 on: July 26, 2011, 08:30:30 PM »
That was the first thing that hit my mind also, Tweakie. That fan looks MUCH better, Steve.
Re: Cylinder Heads
« Reply #263 on: July 26, 2011, 10:09:32 PM »
I hate myself but odd number blade setup will be much smother.
even number work on dc/aux setups but many are odd too.
is that a torsional front hub/balancer?
made my year :)
Re: Cylinder Heads
« Reply #264 on: July 27, 2011, 05:32:33 PM »
made my year :)
When you build your V8 you can have as many blades as you want.  Haahah!!  The 8 blades actually came from a member of another board. Said something like "if I made one it would have 8 blades because" so I was making a new one anyway. I made it to his spec and posted it mounted on the engine the same day.  Now he is making a 9 blade. I already have a design for a 13 blade if the hint of a challenge is made.
That is a mock balancer/pulley. It houses a clutch bearing so I can start the engine.
Have you seen the guy at CNC Zone who is building this engine at 1.5:1 scale? I think he will finish before me.
Re: Cylinder Heads
« Reply #265 on: July 28, 2011, 01:30:15 AM »
i just wish ...:)
Re: Cylinder Heads
« Reply #266 on: July 28, 2011, 08:06:50 AM »
i just wish ...:)
Give it a try!  Start out with a simple steam engine. If that goes well build a milti cylinder steamer. If that goes well build a 2 stroke gas engine. Work your way up from the basics. That's the way 90% of the engine builders do it. Start small.
Re: Cylinder Heads
« Reply #267 on: July 28, 2011, 01:43:30 PM »
Getting closer!
I broke a sparkplug so I need to make a few more then it on to the exhaust pipes.
Re: Cylinder Heads
« Reply #268 on: July 28, 2011, 01:50:28 PM »
If anybody is interested I am making the plans available for the blower conversion. They will be $25USD via Paypal to pross396@wowway.com
They are 27 pages that include the blower, intake manifold, all linkage parts, parts list, ect.
Re: Cylinder Heads
« Reply #269 on: July 30, 2011, 12:28:53 PM »
i just wish ...:)
I have a coke bottle kit, things have been moving slow but I have not given up.
And do you have complete plans for this or just the blower?
thanks for the inspiration
