Hello Guest it is October 21, 2026, 12:03:29 AM
Author Topic: Cylinder Heads  (Read 778700 times)
Re: Cylinder Heads
« Reply #150 on: January 30, 2011, 04:56:56 PM »
Made a few carb parts today
Air bleed adjust screw
Fuel adjusment screw
Fuel fitting
Finished the machine work on the rear float bowls by adding the fuel passages.
Re: Cylinder Heads
« Reply #151 on: February 06, 2011, 02:39:22 PM »
Scratch carburetor off the list. Thanks to Mr. Bob Farr I was able to get a piece of brass to make the barrels. Everything is made except the throttle lever and the gaskets. I think I'm just going to wait until everything is done and make gaskets for everything all at one time.
The screw to the right adjusts the fuel and is adjusted at full throttle. The screw in the center will adjust the air bleed to lean out at idle.
Re: Cylinder Heads
« Reply #152 on: February 06, 2011, 04:44:18 PM »
Awesome job, Steve. Can't wait to see a video of it running.
Re: Cylinder Heads
« Reply #153 on: February 06, 2011, 05:21:25 PM »
You have no idea!!
Re: Cylinder Heads
« Reply #154 on: February 06, 2011, 08:55:50 PM »
Wow....this is really amazing.  Really cool! :)
Re: Cylinder Heads
« Reply #155 on: February 12, 2011, 02:24:04 PM »
Scratch the crankshaft off the list. I made the main bearings and installed the shaft. It is a bit snug but it will seat itself in no time. There's going to be a party tonight.
Re: Cylinder Heads
« Reply #156 on: February 12, 2011, 03:43:32 PM »
WOW !
4 Bolt mains no less !
(may have been mentioned earlier, but deserves a repeat if so)
Looking real good Steve.
Hope to see you "twist 'er tail" soon.
Great work, THANKS !
Russ
Re: Cylinder Heads
« Reply #157 on: February 12, 2011, 04:25:06 PM »
Thanks Russ!
Re: Cylinder Heads
« Reply #158 on: February 15, 2011, 12:52:54 PM »
Made a few more parts. I couldn't find a cool looking oil drain screw so i made one.  I didn't want just a plain hex head screw.
I also made a PCV valve. I'm not to sure it will do anything but what the heck. It is a stem with a cap. In the stem is a 1/8 inch ball and a spring to help seal when the crank case goes negitive.
Re: Cylinder Heads
« Reply #159 on: February 21, 2011, 04:48:48 PM »
SNOW DAY!!!!!!!!!!!!!!!!!!!!!!!
Finished my pistons on this fine day off.
I made a few spares in case I made a boo boo. All are useable. They were made from 7075 if anybody is wondering. I had a piece so I used it but 6061 would have been fine also.
I also had time to make the motor mount posts. They are the same as the Peewee mounts. I think I detailed how they were made in that thread.
