Hello Guest it is October 21, 2026, 02:27:38 AM
Author Topic: Cylinder Heads  (Read 778833 times)
Re: Cylinder Heads
« Reply #180 on: March 23, 2011, 07:32:59 PM »
Made a few more pieces.
Made the rear cover, front cover, and the gear case for the blower.
Re: Cylinder Heads
« Reply #181 on: March 24, 2011, 08:18:50 AM »
WOW!!!!!!
   I don't know how I missed this thread........  That has got to be one of the coolest things I have seen in a while!!
Did you make that with JUST your Mill and Lathe? if other machines what?
would you sell or give your CAD files?  Now I want to make one............ hehehheee (probably dont have the time though).
Thank you, so very, very much for sharing this project,
scott
Re: Cylinder Heads
« Reply #182 on: March 24, 2011, 08:59:45 PM »
WOW!!!!!!
Thanks Poppa for the kind words.
I have a Bridgeport, Bench top CNC mill that I built, and a manual lathe.
I do plan to sell the plans to build this thing. I have a mountian of work into the project as a whole so I can't give them away.
Re: Cylinder Heads
« Reply #183 on: March 26, 2011, 03:13:45 PM »
I had my pulley stock show up in the mail yesterday so there went my day off. The new day off is tomorrow.
I made this little fixture to hold the pulley on center. The tail section is exactly 3/4 so it can be chucked in a collet. The bore is snug as a bug. I put a 4-40 screw in the side to hold the stock from spinning. Not sure if i even needed it. I had a real wrestling match going when I tried to get the finished gear out.
After the slug of pulley was in the holder, the stock was drilled and reamed. Then the inside was bored out to diameter. Then the entire fixture was taken over to the rotary table for drilling. Then the piece was removed and deburred. Easy enough. The most important thing i think would be to hit the center of the pulley OD. I would think the belt will have a hard time staying on in the pulleys were wobbling.
Looks mean as he!!
Re: Cylinder Heads
« Reply #184 on: March 27, 2011, 09:39:39 AM »
Nice, where's the pics of the rotors that fits in that sucker?
Re: Cylinder Heads
« Reply #185 on: March 27, 2011, 04:23:34 PM »
Haven't made them yet.
Re: Cylinder Heads
« Reply #186 on: March 27, 2011, 11:03:42 PM »
Can you make a V16? That would be superly powerful for a kit car of some kind..
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Cylinder Heads
« Reply #187 on: March 28, 2011, 10:27:23 AM »
If somebody wants a real challenge then one of these engines in miniature would be the one  >:D
http://www.royalscotsgrey.com/deltics.htm
Graham
Re: Cylinder Heads
« Reply #188 on: March 28, 2011, 03:02:38 PM »
Graham
Already been done. A guy named Clem Tomlenson
http://www.craftsmanshipmuseum.com/Tomlinson.htm
Re: Cylinder Heads
« Reply #189 on: March 28, 2011, 03:06:07 PM »
I could. I have the block and crankshaft drawn already. It would be easy to finish the drawings.
