Hello Guest it is October 21, 2026, 04:22:52 AM
Author Topic: Cylinder Heads  (Read 778961 times)
Re: Cylinder Heads
« Reply #160 on: February 24, 2011, 08:44:53 PM »
I decided to have some fun today and make a pattern for some thing I have been thinking of casting.
I used some lexan that was given to me. I pinned two pieces together so I can cast in sand.
Started roughing it out with a 1/4 inch cutter.
Then I made some horizontal passes with a 1/8 inch ball nose. Can see more detail coming out.
Then vertical passes .006 on center for a few hours.
Then to the manual mill to remove the extra off the bottom
Re: Cylinder Heads
« Reply #161 on: February 24, 2011, 09:01:04 PM »
Awesome stuff, Steve. Work like that makes you want a trunnion table, don't it!
Re: Cylinder Heads
« Reply #162 on: February 24, 2011, 09:27:49 PM »
I'll take one of everything please!!
Re: Cylinder Heads
« Reply #163 on: February 24, 2011, 10:01:35 PM »
Nuthin' but COOL !
Awsome don't even come close.
Ok, so now you need 2 carbs. And what are you going to use for a belt ?
Just put it on as a dummy, no rotors necessary (unless you got plans for em')
Way to go Steve !
Gotta see this thing blow some smoke.
Wicked !
Re: Cylinder Heads
« Reply #164 on: February 24, 2011, 10:37:10 PM »
I made 3 carbs a few weeks ago. It will use a 1/2 inch wide MXL belt. I have 3 lobe rotors planned. It will be no dummy.
Re: Cylinder Heads
« Reply #165 on: February 24, 2011, 11:23:30 PM »
Any reason why you decided to make your carbs rather than to use something like a walbro off the shelf?
Re: Cylinder Heads
« Reply #166 on: February 25, 2011, 03:19:59 PM »
Walbro would be way!!!!!!  to big. Alot of the real small RC carbs are made to flow nitro. Also couldn't find one that looked like a holley.
Re: Cylinder Heads
« Reply #167 on: March 02, 2011, 05:55:33 PM »
Not alot of progress but progress none the less. The oil pan is offically done. I drilled the holes for the motor mounts. I also added a hole with a pipe plug to allow for checking the oil level. Now both of the boys are standing proudly on there legs. I mocked one up just to get a feel for how big they will be. SMALL!!
Re: Cylinder Heads
« Reply #168 on: March 10, 2011, 09:18:00 PM »
This is incredible!
  •  9,374 9,374
Re: Cylinder Heads
« Reply #169 on: March 11, 2011, 12:42:23 AM »
Really great work.
Is that a 10 cylinder, 2 stroke rotary engine I see in your in tray ?
