Hello Guest it is October 21, 2026, 12:03:37 AM
Author Topic: Cylinder Heads  (Read 778702 times)
Re: Cylinder Heads
« Reply #70 on: August 02, 2010, 06:17:09 PM »
Hello everybody!
Finally managed some progress this week. I spent the weekend at the Detroit Maker Faire so today I almost finished the intake manifold. I drilled all the holes for mounting and fuel and water passages.Bolted it on the block to be sure it fits. The only thing left is to drill the distributor hole and finish threading a few holes and it should be a keeper.
Re: Cylinder Heads
« Reply #71 on: August 02, 2010, 07:12:04 PM »
Coming together Steve, i hope your getting that nice feeling of satisfaction.
Re: Cylinder Heads
« Reply #72 on: August 02, 2010, 07:23:27 PM »
I'm about a year away from that feeling.
Re: Cylinder Heads
« Reply #73 on: August 06, 2010, 05:30:55 PM »
The valve corvers took forever but all went well. I put a piece of sawed off stock in the mill and drilled the mounting holes and did all the machine work for the bottom side. All was done CNC. All 6 of them.
The block was rotated around holes were drilled to create the counter bore for the screw heads.
The top of the valve cover was brought to size
Then the edges of the counterbore were rounded off with a itty bitty endmill.
Last the corner rounding endmill was used to finish off the top and create the top protrusion.
While I was waiting on the mill I was busy tapping everything that needed to be tapped.
Re: Cylinder Heads
« Reply #74 on: August 13, 2010, 04:45:55 PM »
Hello all!
Managed some garage time today. Worked on the bell housing.
I still need to drill the hole pattern to mount the piece but that should be a quick deal!
Re: Cylinder Heads
« Reply #75 on: August 13, 2010, 04:50:08 PM »
Love it Steve!
Every piece you add brings the coolness factor up a notch by a MAJOR percentage -  ;)
Re: Cylinder Heads
« Reply #76 on: August 13, 2010, 05:25:39 PM »
Great going, one for yourself and i guess your making the other one for me........ :D
Re: Cylinder Heads
« Reply #77 on: August 13, 2010, 07:41:15 PM »
Good one!!
One with a carb, one with a blower and 2 carbs.
Re: Cylinder Heads
« Reply #78 on: August 14, 2010, 07:05:06 AM »
I'll take the one with the 2 carbs and blower.....make sure it works before sending it to me.... ;)
You must  admit that with CNC making another becomes a lot less time consuming. You may want to consider selling the gcode to make one.
Keep posting pic's as i can only write and can't read.... ???
Re: Cylinder Heads
« Reply #79 on: August 14, 2010, 08:03:14 AM »
Yeah, pics are like food, and were always starving! Awesome job. LOVE it!!
