Hello Guest it is October 21, 2026, 05:26:17 AM
Author Topic: Cylinder Heads  (Read 779040 times)
Re: Cylinder Heads
« Reply #30 on: July 08, 2010, 03:38:11 PM »
I would definitely do the crank in a lathe. The cam lobe profile in a mill.
The tedious  part is getting all the cam lobes in the correct orientation on the shaft.
How much valve lift will this engine be running? and what ratio rockers. Curious.
Ed VanEss
Re: Cylinder Heads
« Reply #31 on: July 08, 2010, 05:00:41 PM »
(;-) Your lobe must be correctly designed to run with your lifter. The curve is the actual ramp of the lobe. You can run right up to the edge of the lifter with the ramp design without problems.(;-)
You are talking about a curved flank lobe. We are on the same page. I have milled a cam with a curved flank and i have made them on the lathe and the lathe is about 4 times faster doing it the way i do. I do make one piece cams, not the built up type. Nothing wrong with them, I just perfer the one piece design
Alot of guys just cut into a lobe, turn the lobe, and then cut there way out making a lobe with flat flanks. It is faster but the time spent making roller lifters or ball nose lifters needs to be added in.
This cam was made for a V4 i finished a few months ago. I get alot of positive comments on the sound.
http://www.youtube.com/watch?v=1-JRQGPswVA
Re: Cylinder Heads
« Reply #32 on: July 08, 2010, 05:04:28 PM »
Take a look at this. It is alot easier than you think.
http://www.mikes-models.com/camarticle.html
.070 lift  280/280 duration 110 seperation
Re: Cylinder Heads
« Reply #33 on: July 08, 2010, 05:58:14 PM »
Steve the way we do it here is generate the lobe profile. Load the blank into the 4th between centers. Rotate to a start point on the blank. Cut the profile onto the first lobe. Move over in X to the next lobe rotate the cam to orientate the next lobe center and cut that lobe then on to the next. Once you start it is very easy to index the separate lobes at the proper lobe centers. IF you want a split profile just substitute the intake profile for intakes and exhaust for exhaust.
I am sure your process works for you but 47 cuts per lobe?? that is a lot of setup(;-)
Keep us up to date on your project.  Mini's look cool but I will stick with the big boys
Re: Cylinder Heads
« Reply #34 on: July 08, 2010, 07:42:46 PM »
The Cam in the posted picture was made start to finish in 5 hours. Even if i had a 4th I'm not sure i could create the Gcode in 5 hours. I'm still real new to all this "drink beer while the machine does it all" stuff. This is just one of those times where it is faster to do it manually.
Re: Cylinder Heads
« Reply #35 on: July 08, 2010, 08:00:51 PM »
Doesn't matter how you do it Steve, It looks really good. And 5 hours is fast for a cam project.
Keep it up.
Ed VanEss
Re: Cylinder Heads
« Reply #36 on: July 08, 2010, 09:05:52 PM »
Heck the Gcode  is the easy part you only have to do it once then use that on every lobe.
Ed is right it doesn't matter how you do it as long as "you do it" and enjoy it.  AND you are doing a FINE JOB.
But if you ever get the chance to play with a 4th axis in CNC you may throw rocks at the lathe method(;-) It can do all the work on the crank or  cam in one setup while you sit back and watch and drink iced tea (or beer). It might seem like MORE work at first but IF you have to build a second one. HUM load blank, load program push start button, drink iced tea.
Re: Cylinder Heads
« Reply #37 on: July 09, 2010, 06:53:15 PM »
Keep it up.
Dont get me wrong, I am open minded to it. If I had a 4th I might try it just to learn something new. I also want to make some blower rotors in a rotary axis but i have none.
Re: Cylinder Heads
« Reply #38 on: July 09, 2010, 06:53:34 PM »
Got a bit more done on the block. I went down both sides of the block with a 5/8 ball nose to give the block it's final profile.
Then with the block upside down, finished the profile.
Then i knocked down the pointed edge in the valley to make it look a bit nicer.
I think for now the block is done. I still need to drill the hole for the distributor but i'm going to wait and drill thru the manifold and block at the same time. It just hit me how small this thing is.
Re: Cylinder Heads
« Reply #39 on: July 09, 2010, 07:35:38 PM »
NEAT. Lookin real good.
 What material did you use for the 4 bolt bearing caps?
Ed VanEss
