Hello Guest it is October 21, 2026, 12:02:51 AM
Author Topic: Cylinder Heads  (Read 778694 times)
Re: Cylinder Heads
« Reply #40 on: July 09, 2010, 07:52:22 PM »
NEAT. Lookin real good.
 What material did you use for the 4 bolt bearing caps?
I use 6061-T6 for almost everything.
Re: Cylinder Heads
« Reply #41 on: July 10, 2010, 08:14:56 AM »
Enjoy following this thread. Keep the updates coming.
Re: Cylinder Heads
« Reply #42 on: July 10, 2010, 08:38:15 AM »
Looking forward to the transmission build,  ;)  excellent project, keep up the fine work.
Re: Cylinder Heads
« Reply #43 on: July 10, 2010, 10:07:23 AM »
Steve, it's really coming along nicely, thanks for sharing-
Re: Cylinder Heads
« Reply #44 on: July 10, 2010, 02:43:18 PM »
I'm looking foward to the transmission build also. Which one of you is building one?
Re: Cylinder Heads
« Reply #45 on: July 10, 2010, 03:13:23 PM »
I am holding out for the Hypoid rear end gearset(;-)
Re: Cylinder Heads
« Reply #46 on: July 10, 2010, 05:08:34 PM »
I'm waiting for Arts new gear program, should be able to create some fancy drive train.
Re: Cylinder Heads
« Reply #47 on: July 10, 2010, 05:27:24 PM »
I made the timing cover today. The cover was cut using the CNC machine then the counterbores were made manually in the drill press. I now have to chuck it up in the lathe and bore the inside to recieve the front crank seal. I think the cover will be polished and buffed to a high gloss.
Re: Cylinder Heads
« Reply #48 on: July 10, 2010, 09:33:09 PM »
BR549, show some pics of how you make your cams in the 4thaxis.
Great work and thread Steve!
Re: Cylinder Heads
« Reply #49 on: July 10, 2010, 10:15:27 PM »
What size Cap Screws are you using? Looks like #6-32
and I assume you wont be using any paper gaskets?
Fun project to watch being built.
