Hello Guest it is October 21, 2026, 01:20:51 AM
Author Topic: Cylinder Heads  (Read 778767 times)
Re: Cylinder Heads
« Reply #170 on: March 11, 2011, 07:51:34 PM »
Really great work.
Is that a 10 cylinder, 2 stroke rotary engine I see in your in tray ?
That's a 9 cylinder radial that I made from Cox .049 cylinders. Cox .049 were real popular single cylinder engines when I was a kid.
« Last Edit: March 11, 2011, 07:54:49 PM by stevehuck »
  •  9,374 9,374
Re: Cylinder Heads
« Reply #171 on: March 12, 2011, 01:15:02 AM »
Brilliant Steve, I can just imagine the noise that would make.  ;D
(I still have a couple of those little cox engines).
Re: Cylinder Heads
« Reply #172 on: March 12, 2011, 01:17:13 AM »
I guess I need to brush up on Lazycam...I can't even engrave with it yet, course I don't have the mill yet. Hope I can learn on the fly.
Re: Cylinder Heads
« Reply #173 on: March 12, 2011, 06:57:26 AM »
I switched to CamBam about a year ago or so. I have nothing bad to say about Lazycam but i wouldn't have been able to do the blower pattern with it so I needed something a little more powerful. Very happy with CB so far.
Re: Cylinder Heads
« Reply #174 on: March 19, 2011, 04:41:59 PM »
Finished the rods today. I used the CNC machine to cut the rod's profile while fixtured.
The rod plate was put on the fixture. The bushings extend thru the rod and into the fixture so the screws are not relied upon to hold the rods in place.
Re: Cylinder Heads
« Reply #175 on: March 20, 2011, 04:58:36 PM »
Today was fun time in the garage. Did nothing I was supposed to do and everything I wanted to do. I made an adapter plate that will go onto the intake manifold for the blower. The stock intake manifold will not work for this so I will eventually make another one.
Then I made this. It's a long way from being done. Took 7-1/2 hours to make this from a 2-1/2 X 3 inch block.
Then I made the adapter for the duel carb. Screwed up the ears on the flange that the carb sits on. Should have been rotated 90 degrees. I originally had a single carb facing forward. When I went duel carb I forgot they only fit side saddle. Should be fixed in the plans.
That was my day!
Re: Cylinder Heads
« Reply #176 on: March 20, 2011, 11:08:08 PM »
Looks real nice Steve. Every time I check my mail and there's a "Topic Reply" by Stevehuck, it feels like Christmas.  :D I really enjoy watching your progress. Thanks again for sharing with us.
Re: Cylinder Heads
« Reply #177 on: March 21, 2011, 03:53:58 AM »
I feel the same way. I just found this forum and this particular thread is like crack! Every time I get an email regarding this thread, I have to check ASAP to see what's next.
Re: Cylinder Heads
« Reply #178 on: March 21, 2011, 03:37:23 PM »
Thanks Sam for the kind words.
Stoner, I laughed like hell when I read that one. Glad you like it!!
Re: Cylinder Heads
« Reply #179 on: March 21, 2011, 07:22:49 PM »
