Hello Guest it is November 13, 2026, 12:35:50 PM
Author Topic: Bridgeport Knee Mill Conversion?  (Read 1121813 times)
Offline Davek0974
  •  2,606 2,606
Re: Bridgeport Knee Mill Conversion?
« Reply #750 on: March 31, 2018, 09:38:50 AM »
Ok, so i finally got i all bolted up and the new drawbar made, mounted on the mill and, well clearly I still have work to do :(
The idea of allowing the wrench to fall will not work as the mechanism is not slack enough to let it - ok so we go to plan B and use air to push it - this works ok.
Next, the idea of not starting the impact until the Torx bits mate will not work - the Torx bits jam instead of mating about 75% of the time, might be able to improve this a bit by grinding the profiles a bit, will save that for later.
Next, with the wrench being held down, you cant easily insert a tool as it needs to push the drawbar upwards, but the cylinder is pressing it down so it risks cross-threading etc.
So I guess you MUST release the wrench after the tool is released? - I have no idea of the cycle here, all the videos just show it working, no real detail.
Does anyone know what i am missing here - anyone actually built a power drawbar for a threaded tool holding system like BT30??
Offline TPS
  •  2,627 2,627
« Reply #751 on: April 01, 2018, 07:20:45 AM »
what would be to use a hex bolt insteed of torx,
in combination with a long nut it would allow the
screw to go into the nut without any pressure on
the screw.
just thinking.
Thomas
Offline Davek0974
  •  2,606 2,606
« Reply #752 on: April 01, 2018, 07:31:06 AM »
Thanks, I have made some progress now,
I had too much control of the wrench - removing the bottom bar has allowed it to move easily now.
The Torx has better torque rating than hex - I have modified the head a bit with the grinder and that has allowed it to mate easier now.
I am trying to find my PLC software disc so i can set up a simple control logic to get it cycling, its here somewhere.........
Offline TPS
  •  2,627 2,627
« Reply #753 on: April 01, 2018, 07:40:34 AM »
why using an external plc and not the cslab ?
Offline Davek0974
  •  2,606 2,606
« Reply #754 on: April 01, 2018, 07:49:38 AM »
easier to mess about with until I know exactly what i want, thats all.
not good messing about in the cab i think, also easy to put it all to one side if i need to run the mill.
Offline TPS
  •  2,627 2,627
« Reply #755 on: April 01, 2018, 08:02:31 AM »
i mean a outside hex screw with Long nut.
this would the screw allow to go up when you
insert new tool and you don't have to lift the wrench.
Offline Davek0974
  •  2,606 2,606
« Reply #756 on: April 01, 2018, 08:13:35 AM »
Nice, thanks
I'll note that if we get to Mk2 ;)
Offline Davek0974
  •  2,606 2,606
« Reply #757 on: April 21, 2018, 08:13:45 AM »
Ok so the project is still going on :)
I now have a custom screenset, probe, probing macro's etc all working well.
Today I was bothered by some odd vibration I had since fitting the BT30 spindle, here's a short video of the top...
https://youtu.be/MJAr941aL-U
So I blamed the DIY drawbar, made another one, just as bad?
Tipped the head over and had a look and the splined portion of the spindle is clearly bent :(
https://youtu.be/jEhYINbUgzI
The tool section runs very true so not sure how you bugger a spindle like this??
It was like it when i got as i have had no crashes.
Now, not sure what to do really, it took ages to find that spindle, they are not that common. I have sold all my R8 tooling and only have BT30 now.
Can they be straightened?
I could push it out in the garden and torch it - it seems every time i get ahead she kicks me in the 'nads :(
Any ideas?
« Reply #758 on: April 21, 2018, 09:15:46 AM »
Take you time and straighten it while you look for a better spindle.
Mike.
Offline Davek0974
  •  2,606 2,606
« Reply #759 on: April 21, 2018, 11:28:29 AM »
Need to find an approved method first, I don't have much in the way of surface plates etc, do have a 20T press though.
Certainly a PITA though.
QC30 spindles are very rare and it cost a lot too.
