Hello Guest it is October 20, 2026, 11:55:19 PM
Author Topic: Bridgeport Knee Mill Conversion?  (Read 1071362 times)
Offline Davek0974
  •  2,606 2,606
Re: Bridgeport Knee Mill Conversion?
« Reply #220 on: June 03, 2016, 02:30:16 AM »
Sorted it out :)
Just use an output in Mach for each profile - active low, no other use. It comes on as soon as Mach loads and stays on regardless of reset state etc - this output can then control the respective contactor for the VFD needed for that profile.
The supplies will also go through the E-Stop system but this means that the whole startup is now just a matter of clicking on the correct Mach profile :)
Now, lets look at the Z axis...
I am intending to bolt the aux spindle onto the main quill shaft, this means that my Z travel will be reduced but not drastically i think.
It also means I need two Z home positions - can I use ONE Z home switch at the lower position and use the Z home-offset to tell the system where the home is respective to the profile in use??
Questions-
If i have one home switch in the lower position and the head is already above that switch, what happens when i ref-all??
Is there a smart fix for Z upper limit switch or do I have to try and fit TWO limits switches in at the top??
Getting there :)
Offline Davek0974
  •  2,606 2,606
« Reply #221 on: June 03, 2016, 02:41:12 AM »
Hmm, bench-top tests seem to look promising - with a home switch offset of 50mm, when i do a ref-all it moves to the switch, stops, moves off, then reverses 50mm. I think that is just what it needs ?
If the switch is already closed when ref-all is called, it just backs off slowly until it opens - nice, BUT the switch trigger MUST be continuous and not just a passing trigger so a long switch cam will be needed there.
Limits??
« Last Edit: June 03, 2016, 02:44:21 AM by Davek0974 »
Offline Davek0974
  •  2,606 2,606
« Reply #222 on: June 03, 2016, 05:48:10 AM »
Rough draft of power wiring and e-stop circuit...
Offline mc
  •  384 384
« Reply #223 on: June 03, 2016, 09:42:37 AM »
Couple things from a quick look at the diagram, you'll need a limit override switch, and do you really need to have the power for each servo drive use a separate contact?
The same could be said about the ESR relay.
Offline Davek0974
  •  2,606 2,606
« Reply #224 on: June 03, 2016, 09:51:09 AM »
Ooh, good point re the override switch, forgot about that one :)
No real reason for the multiple ESR, just  the way it evolved, will alter that one.
No harm in having the drives on multiple contacts, its a common style of contactor so no need to combine.
Offline Davek0974
  •  2,606 2,606
« Reply #225 on: June 03, 2016, 12:17:33 PM »
Hmm, thinking on the drive home  ;), I can see one reason when that would be needed - if the soft-limits fail and the Z axis rams the head right up or down - there is no hand wheel on the Z axis so no way to get it back down again, although I could simply reach up and spin the pulley by hand.
But apart from that, if the X or Y axis runs off the end then they can be rewound before pressing reset?
An E-stop loop would not be bypassed by the limits override so thats ok.
Offline mc
  •  384 384
« Reply #226 on: June 03, 2016, 02:24:07 PM »
You do have the benefit of being able to move things manually, so you could probably manage without an override button.
I think it would probably be a good idea to wire up your control box to allow for the possibility of adding one later though. Have the limit switch loop come back to a terminal in the control box, before connecting to the E-stop loop, so if you do need to add one later, you've got a nice convenient point to wire one in, with minimal rewiring needed.
Offline Davek0974
  •  2,606 2,606
« Reply #227 on: June 03, 2016, 02:29:51 PM »
Yes i like to wire that way anyway, makes things much easier to trace issues later on when the external stuff comes in on a terminal strip, one by one, no hidden loops etc.
I would like to think that once homing and safe-limits is up and running the only time the hard limits would be it is after a runaway drive and I've not heard of that yet;)
« Reply #228 on: June 05, 2016, 10:31:16 AM »
Problem with having lost of I/O available is you soon find things to do with it and end up with one short :D
Offline Davek0974
  •  2,606 2,606
« Reply #229 on: June 05, 2016, 10:33:35 AM »
I have a bit more on the MPG module ;)
My list is only about half-capacity at present, plenty to play with :)
