Hello Guest it is October 21, 2026, 04:42:51 PM
Author Topic: Bridgeport Knee Mill Conversion?  (Read 1072048 times)
0 Members and 7 Guests are viewing this topic.
Offline Davek0974
  •  2,606 2,606
Re: Bridgeport Knee Mill Conversion?
« Reply #660 on: January 27, 2018, 08:22:23 AM »
I also cant see why it works ok in manual calls with no code loaded (see video) but fails when in code mode????
Offline Davek0974
  •  2,606 2,606
« Reply #661 on: January 28, 2018, 04:57:09 AM »
Ok, i'm getting closer :)
It seems if i call all tools my the MDI it works, but will verify this with a repeat TC code program in a minute.
When you call a tool by MDI using M6T100 the Z DRO does NOT change.
Now, before i always set my Haimer probe by typing 100 in "Current Tool" DRO on the 2010 screen-set - do this and the Z DRO gets TLC applied to it - this is the cause of my issues i think, looks like the "Current Tool" DRO runs G43 H********* when you press enter on it - thus the cause of my lost Z travel.
I'm off to run some more tests but it feels like I will have to remove the "Current tool" DRO for safety reasons and do it all MDI, no biggy.
Offline Davek0974
  •  2,606 2,606
« Reply #662 on: January 28, 2018, 05:26:37 AM »
Nope, failed again :(
I manually ran through my whole tool rack, 20+ tools using MDI TxxM6 G0Z0 and every time it worked perfectly 100% tool on the TOM.
Loaded up the code, soft limit on Z Min warning, bypass, crash(e-stopped to avoid) The Z axis just dives.
Here is the screen after i stopped - the Z axis is at +85 and the code is calling for Z2 ??
The Offsets screen...
The Z of 186mm is about right - i had the z at about +30 when zeroing with the Haimer which is about 150mm long.
So, i'm stuck again - it works well in manual but can't run code :(
Have attached the exact code file below.
Offline Davek0974
  •  2,606 2,606
« Reply #663 on: January 28, 2018, 05:59:44 AM »
Probably digging myself in deeper here but could it be how i have my tool table setup?
I measure all my tools in a height-setter which feeds the result straight back to Mach TT, all tools have a height including the Haimer probe.
Now, i just went back and put the probe back in the spindle, and the Z was off by exactly the height of the probe - this is why it crashes.
BUT why only in code and not manual - it works perfectly in manual.
So confused now.
Offline TPS
  •  2,627 2,627
« Reply #664 on: January 28, 2018, 06:11:13 AM »
hi,
is it possible that your are doing th TLC twice ?
1. with the c-axis (knee)
2. SetCurrentTool(Tool) (m3 internal TLC)
just thinking while i went through your post's.
Thomas
Offline Davek0974
  •  2,606 2,606
« Reply #665 on: January 28, 2018, 06:15:11 AM »
I was unaware what setcurrenttool actually did - that may be a lead there, thanks.
If i leave setcurrenttool out, any idea what would happen??
Offline TPS
  •  2,627 2,627
« Reply #666 on: January 28, 2018, 06:22:35 AM »
do a little test to see what Setcurrenttool does.
-load 1024.set
-put in the tooltable  height 10.0 for tool1
-enter tool 0 in the tool Information dro
-push zerro z button
-enter tool 1 in the tool Information dro
-watch z coordinates
Thomas
Offline TPS
  •  2,627 2,627
« Reply #667 on: January 28, 2018, 06:25:38 AM »
i think, as far i have walked through your code,it will work like you expected,
because the TLC is done by your c-axis.
Thomas
Offline Davek0974
  •  2,606 2,606
« Reply #668 on: January 28, 2018, 06:27:22 AM »
That was my conclusion, off to try as soon as i stuff this sandwich down :)
Offline Davek0974
  •  2,606 2,606
« Reply #669 on: January 28, 2018, 07:40:29 AM »
Thomas
NAILED IT!
Well spotted, TPS,
removed the Setcurrenttool line and it all fell into place :)
You can use the "Current tool" DRO anymore as it has no idea what the current tool is but i can live with that, i guess it could be fixed by adding a line to the macro that sets a pseudo current tool DRO on =screen to show the last selected tool call.
But its all working, part made, no mess ups.
