Hello Guest it is October 30, 2026, 12:10:02 AM
Author Topic: The Laser Project.  (Read 3855379 times)
0 Members and 17 Guests are viewing this topic.
  •  9,375 9,375
Re: The Laser Project.
« Reply #740 on: February 15, 2013, 03:08:59 AM »
I have been following recent work (done on another forum) with low power lasers producing images using printer Toner.
I had to give it a try using my 40W CO2 laser and this was my first successful test run on a scrap piece of Oak.
IMPORTANT - It should be noted that it is unwise to experiment with fine powders in a confined space so for any that follow please observe the necessary safety precautions and always have a suitable fire extinguisher standing by.
  •  9,375 9,375
« Reply #741 on: February 17, 2013, 07:27:24 AM »
Something that just had to be tried…
As mentioned earlier, others have a lot of success using lasers to melt / fuse printer Toner onto the surface of wood and I just wondered if it would work with copper clad PCB material.
There are a couple of difficulties to be overcome – firstly getting a thin and even layer of the toner powder onto the copper surface and secondly getting a low enough power level from a 40 Watt laser so as not to completely vaporise the toner.
Once these challenges have been overcome – it is a breeze.
« Reply #742 on: February 17, 2013, 09:36:32 AM »
That's nice Tweakie. I am picturing a lot of mess after dealing with the toner ;)
  •  9,375 9,375
« Reply #743 on: February 17, 2013, 11:35:02 AM »
Hi Dan,
You are not wrong - the mess was not as bad as I was expecting it to be, but I would not want to be doing this as my day job.  ;D
  •  9,375 9,375
« Reply #744 on: February 18, 2013, 07:11:51 AM »
One more test using the dreaded Toner.  ;D
  •  9,375 9,375
« Reply #745 on: March 07, 2013, 11:03:21 AM »
The Parliament Building is probably the most photographed building in Hungary. It's symmetry is just outstanding.
This laser produced rendering is just 50mm square and I think, makes for a good example of the detail that can be reproduced within lithophane’s in general.
Produced from a standard JPG image which I cropped to make it rectangular then using the Mach3 Laser / Impact plugin I scaled it to fit the Corian blank, set the max. laser power to approx. 30% and hit Cycle Start.
By the time I had finished off a can of beer it was done.
« Reply #746 on: March 07, 2013, 05:38:55 PM »
Very nice Tweakie.......... your just showing off now............. and I like it.
« Reply #747 on: March 08, 2013, 04:47:43 PM »
Wow. Very nice Tweaks. Awesome as usual.
  •  9,375 9,375
« Reply #748 on: March 09, 2013, 02:32:21 AM »
Thanks Guys, but I can’t help thinking that Art deserves the credit here.
Although, over the years, I have made a few minor changes to the code (basically to suit the operation of my own machine) the Impact / Laser Engraving plugin was written by Art in 2007 – long before we even had a laser to test it with. He certainly has foresight and his software never ceases to amaze me.
My current worries are that I will become a Dinosaur - because this plugin works so well, I will never be able to leave Mach3 for Version 4.  ;D
There was some discussion (in another thread) where I doubted that laser produced lithophanes could actually produce a resolution equal to spindle engraved versions but since getting hold of some genuine Corian to try - I now think that it is possible to get extremely close.
The big advantage is that the laser takes half an hour to produce a small, 0.1mm step-over, litho that may take half a day with spindle engraving.
« Reply #749 on: March 09, 2013, 11:02:40 AM »
YOU become a dinosaur? doubtful. I feel like a T-Rex because I don't even have a laser. Definitely on the 'to do' list, and climbing closer to the top.
