Hello Guest it is October 30, 2026, 12:47:35 AM
Author Topic: The Laser Project.  (Read 3855894 times)
0 Members and 18 Guests are viewing this topic.
Re: The Laser Project.
« Reply #680 on: October 06, 2012, 07:00:40 AM »
Tweakie, have you done any test or comparisons with the different woods and their surface finish, density and moisture content?  I'm just thinking if those 3 variables were monitored maybe a formula could be created to give consistant results.
You do some of the neatest stuff Tweakie!
  •  9,375 9,375
« Reply #681 on: October 06, 2012, 07:10:41 AM »
Hi Brett,
I had not even thought about measuring moisture content (I do have the equipment to measure that) but surface finish certainly does play a big part in determining the result.
Any thoughts or suggestions on the easiest way I can determine density ??
« Reply #682 on: October 06, 2012, 08:07:48 AM »
I have used this before.
http://www.engineeringtoolbox.com/wood-density-d_40.html
I don't know how accurate that will be really because of growing variables but it should get you with in a reasonable range.  You could also just measure and weigh and account for moisture content or its probably overkill but you could do a displacement vs weight test.  Maybe vaccum seal the wood in a known size bag and sink it in a pan of water and measure the amount of water that gets displaced.  I wouldn't think you would need that at all unless you were trying to measure odd shaped pieces.
  •  9,375 9,375
« Reply #683 on: October 09, 2012, 06:00:10 AM »
Thanks for the info Brett, it is most helpful.
Overall the Obechi seems to give me the best results with, contrast ratio, so far but I still have a few more different woods here to try.
« Reply #684 on: October 09, 2012, 06:17:45 AM »
Hi Tweakie,
Why are there vertical lines on the last one?
  •  9,375 9,375
« Reply #685 on: October 09, 2012, 06:32:58 AM »
It's the grain of the wood Dan.
« Reply #686 on: October 09, 2012, 06:40:59 AM »
Ah... They are so evenly spaced and bright (I would have expected the grain be darker than rest) that it didn't occur to me it was the grain ;)
« Reply #687 on: October 09, 2012, 07:02:10 AM »
Tweakie, what are the physical dimensions of the piece in the last picture you posted?
  •  9,375 9,375
« Reply #688 on: October 09, 2012, 07:24:38 AM »
Hi Brett,
It's 150mm x 95mm.
« Reply #689 on: October 13, 2012, 02:50:57 AM »
WOW  Tweakie.... the contrast is perfect....excellent
