Hello Guest it is October 30, 2026, 12:45:07 AM
Author Topic: The Laser Project.  (Read 3855863 times)
0 Members and 22 Guests are viewing this topic.
  •  9,375 9,375
Re: The Laser Project.
« Reply #360 on: April 21, 2011, 06:38:05 AM »
A quick bench test, just check it all works OK now that it has been assembled up.
Here, the laser was fired for a 1 second burst (pressing the trigger then camera shutter almost simultaneously) at a setting of 20.5% PWM which, according to the Synrad power graph is approx. 25% of the lasers output power. It makes an instant and satisfying 'pop' as the cardboard ignites.
This is the beam straight out of the laser (approx. 6 mm diameter) without any lens, when it has been focussed to a point the size of a pin prick (0.04 mm) it should be quite awesome.  ;D
« Reply #361 on: April 21, 2011, 07:29:37 AM »
Hello Tweakie. I need your help. My machine computer hard drive collapsed.I had in the hard drive the licenced mach3 programm.I dont know yet if i can retrieve it.Do you know in which file there is written the licence data? I dont remember under which name i had purchuased it!!
  •  9,375 9,375
« Reply #362 on: April 21, 2011, 07:35:55 AM »
Hi Buddy, it is called 'Mach1Lic.dat' and it is in the Mach3 folder. If you have really lost it then contact Scott and he will re-issue the license but you may have to specify the name or possible names you used when you purchased it.
« Reply #363 on: April 21, 2011, 07:39:07 AM »
Thanks very much
  •  9,375 9,375
« Reply #364 on: April 26, 2011, 04:24:40 AM »
Just something I tried during the holiday - as opposed to 'inlay' this is 'onlay' or laser marquetry.
This example is rubbish really because it was produced by cutting two identical images from different veneers and then transposing the parts. It has no allowance for tool radius offset so I have filled the kerf just to see the end result.
By thickening the outline of the original .dxf I should be able to produce two toolpaths (one for cutting on the outside of the line and one for cutting on the inside of the line) then, if I get it right, the parts should fit exactly with no visible kerf.  :-\
A lot more experimenting before I get it right but it is an interesting technique and eminently suited to lasers.
  •  9,375 9,375
« Reply #365 on: April 26, 2011, 07:52:38 AM »
My Boss took an early lunch today and while the cat's away..........
It took two attempts to get the tool radius offset correct but once I got it right the parts do fit pretty well.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #366 on: April 26, 2011, 11:31:32 AM »
So is this laser cutting a negative and positive and you are switching the cutouts? I am not sure of what I am seeing and havent really followed the thread.
  •  9,375 9,375
« Reply #367 on: April 26, 2011, 11:46:35 AM »
That's about it.  ;)
( I haven't shown all the leftover parts that are thrown away).
« Reply #368 on: April 26, 2011, 08:47:41 PM »
WOWSER Tweakie that is great work. Good Job
PS You are going to have ART drooling all over the shop.
  •  9,375 9,375
« Reply #369 on: April 27, 2011, 12:48:46 AM »
Thanks Terry, who knows, I could be stalling out at the craft fairs later on in the year.  ;D
