Hello Guest it is November 07, 2026, 10:27:34 AM
Author Topic: Chiron FZ12 on its way sometime soon(ish)  (Read 896965 times)
0 Members and 10 Guests are viewing this topic.
  •  9,375 9,375
Re: Chiron FZ12 on its way sometime soon(ish)
« Reply #350 on: September 04, 2013, 06:46:53 AM »
Excellent work Hood.
I think rapid moves with the Haimer in the chuck is real scary to watch.  ;D
« Reply #351 on: September 04, 2013, 07:22:08 AM »
;D
They are not cheap that is for sure but you only live once so what the hell ;D
« Reply #352 on: September 04, 2013, 10:34:56 AM »
I know Tweakie. Nearly gave me a heart-a-stroke!  ;D
« Reply #353 on: September 05, 2013, 08:55:16 AM »
Have redone the vid with the camera this time, bit better quality.
http://youtu.be/7jpnjLVKZN4
« Reply #354 on: September 06, 2013, 07:28:20 AM »
Thanks Hood. Think the Haimer doesn't have sufficient resolution to show the true homing accuracy ;)
« Reply #355 on: September 08, 2013, 09:00:37 AM »
Yes and no Dan :)
The needle can be seen to be at exactly the same position each time and that tells me that both the Haimer and the Index homing are very accurate :)
« Reply #356 on: December 23, 2013, 10:34:33 AM »
Well I got a chance the last week to start machining a new block for the valves, all went well and it looked good, see pics below.
I needed one of the valves in the centre as it was leaking quite badly, I had been watching eBay ever since I got the Chiron but have not seen any so decided just to bite the bullet and get a new one from Festo. Thats when the problems started, they could find no reference to the part number at all and they reckoned it must have been a special made for Chiron, they didnt have anything that was a direct replacement either and suggested I contact Chiron to see if they had one. I had already been in touch with Chiron regarding the spindle/drawbar/bellevilles and they had told me they had no spares at all for the machine as it was so old, they couldnt even help me out with a manual or any info about the machine, that was quite a surprise as I thought German Companies were supposed to be super eficient :D
 Anyway that was a big problem and I had to think of something else. I could have chopped the block in two and removed the centre portion and got some  other valves to do the job but I decided to just scrap the valves and go with others. I had previously purchased some SMC valves and manifolds from eBay but was a few short, I found some more  on USA eBay so ordered them and they arrived on Friday.
 I set to work welding up a plate to replace the original manifold and machined two blocks to hold the two big cassette valve and then screwed the SMC manifold to it. The SMC valves are 1/3 the size of the old Festo ones and have more flow.
 I got things fitted yesterday and tested out and all is working well, today I finished off rewiring everything and tidying up the pipework a bit, still have a small leak from one of the cassette valves but it is minimal compared to all the leaks before and I can get a new cassette valve so no problems there :)
Previously the compressor had been cutting in every 5 minutes, now it is over an hour unless of course I am doing tool changes.
Very happy with the way things have gone :)
« Reply #357 on: December 23, 2013, 10:37:39 AM »
Here are the pics of the new valves and also the pipework from the front, I have  also attached  a pic of the original setup.
« Reply #358 on: March 02, 2014, 02:57:35 AM »
Fantastic to see the machine working.
I bought one too. Has all the electronics connected.
I want to keep the Siemens drives and use Mach to control it.
I will still find a suitable break out board.
Your blog has been an excellent lead into my rebuild.
Thanks for all the info.
Well done
« Reply #359 on: March 02, 2014, 03:27:15 AM »
If keeping the original Siemens drives you will need a controller capable of analogue output such as the CSMIO/IP-A that I use. I am very happy with the CSMIO, it is definitely the best controller I have used with Mach so far.
