Hello Guest it is October 30, 2026, 12:12:24 AM
Author Topic: The Laser Project.  (Read 3855423 times)
0 Members and 13 Guests are viewing this topic.
Re: The Laser Project.
« Reply #840 on: February 01, 2014, 07:14:39 PM »
I did some tweaking on the feed/power level when cutting the .032" basswood and have been able to cut tweakie-bikes where the features are 175 microns wide.  At 150 microns wide they are a bit too fragile to handle... the structure is barely more than ash.  I need to find some material that the 405 nm light does not char like wood does or melt/fuse like most plastics.
I've also been engraving some desktop name stands for some friends... on small wooden matches with 500 micron tall letters... I am becoming a connoisseur of dollar store match sticks.  One side is always finished quite well.  The others are usually rather rough.  Plus the boxes are handy for transporting teeny-tiny tweakie-bikes.
A friend is getting me some UV curing resin to try some stereo lithography.
« Last Edit: February 01, 2014, 07:17:41 PM by texaspyro »
Offline frasej
  •  23 23
  • Jay
« Reply #841 on: February 01, 2014, 11:04:48 PM »
Try craft foam.  The 2mm style cuts very easily with little to no charring.
Jay
Offline frasej
  •  23 23
  • Jay
« Reply #842 on: February 18, 2014, 05:56:12 PM »
Can anyone explain the following... Below are two images, one is an extreme closeup of the other image.  Notice that instead of straight lines, the lines appear to be wavy. This was burned onto balsa wood and I was wondering if it's the grain that is causing the waviness?
Jay
« Reply #843 on: February 18, 2014, 07:47:31 PM »
Are you perhaps using all thread rod (machine screw thread) for lead screws?
John Champlain
Offline frasej
  •  23 23
  • Jay
« Reply #844 on: February 19, 2014, 08:18:57 AM »
Eww, no.   All Chinese lead screws.
Jay
  •  9,375 9,375
« Reply #845 on: February 19, 2014, 08:32:19 AM »
Loose lens or mounting perhaps ?
Offline frasej
  •  23 23
  • Jay
« Reply #846 on: February 19, 2014, 08:54:39 AM »
Loose lens makes more sense.  I have it wrapped in Teflon plumber's tape but it is still easily moved.  I may need to add some more.  I hadn't thought of that, thanks.
Jay
« Reply #847 on: February 19, 2014, 01:34:23 PM »
Well, a warped screw and slight play in bearings might explain it.  Would probably not be noticeable when using a spindle.  Does it change when switching from a horizontal engraving to a vertical?
John Champlain
Offline frasej
  •  23 23
  • Jay
« Reply #848 on: February 19, 2014, 03:06:12 PM »
I wrapped more tape around the threads of the lens and put it back on.  There is still a little wobble in the burn, but not nearly as much as before.  The lines don't seem to cross each other any more.  So it probably was just a loose lens.  I've never tried going perpendicular to the direction I was burning in.  I'll have to give that a go and see.
Jay
« Reply #849 on: June 03, 2014, 04:32:22 AM »
Hi texaspyro, I'm very impressed by your results. Can I ask you how you managed to get such a tight focus? Also, would you recommend your setup to cut ~mm sized features in kapton?
