Hello Guest it is September 30, 2026, 10:36:39 PM
Author Topic: Gertrude Gets Some!  (Read 713479 times)
« Reply #300 on: August 21, 2010, 10:47:33 PM »
wish me luck with this one... 25%bigger than the biggest rign i have ever cut, 2.7 million lines of code..
  •  9,374 9,374
« Reply #301 on: August 22, 2010, 12:21:13 AM »
Keep this up Chris and you will be the first person to exceed the licenced Mach maximum line limit.  ;D
As always excellent work.
« Reply #302 on: August 22, 2010, 01:43:18 AM »
is there one????
wow??? never considered that? the longest path in this series is about 1.2million lines and the rest are saved out in a per index fashion?
not got to cut this yet, probably tommorow actually, hope i dont hit a snag?
  •  9,374 9,374
« Reply #303 on: August 22, 2010, 03:52:16 AM »
Mach3 has a limit of 10,000,000 lines of Gcode even after licensing.
Still a way to go Chris.  ;D
« Reply #304 on: August 22, 2010, 04:19:56 AM »
phewwwwwwww
lol
Ok roughing done, now the first finishing pass :)
Had to cut up a energy drink can to get a tube remelt thick enough
off to the trusty lathe for finishing and truing
Hook her onto the conical clamps and setup time
load path
and rough!
roughing done after 3 stepdown levels
finishing pass started :)
« Reply #305 on: August 22, 2010, 05:50:36 AM »
Rotary pass done, 2h later
add some oil.. (some people claim this helps, i use it but honestly cant tell any difference when using it)
start the index passes (new cutter.. grr K.O'd the last one with the oild bottle!
« Reply #306 on: August 22, 2010, 06:55:52 AM »
Why the switch to DeskProto?
« Reply #307 on: August 22, 2010, 02:54:48 PM »
RhinoCam rides on top of Rhino, rhino has a max mem usage of 3gb so very large mesh files with tight stepovers are nigh impossible to path in RhinoCam at current. I hope the release of Rhino5 64Bit will mean rhinocam goes 64bit too :)
« Reply #308 on: August 22, 2010, 05:13:29 PM »
finally done!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #309 on: August 23, 2010, 12:46:20 AM »
That is truly amazing, from concept to part how many hours are in something like that?
Graham
