Hello Guest it is September 30, 2026, 09:50:38 PM
Author Topic: Gertrude Gets Some!  (Read 713465 times)
« Reply #150 on: August 12, 2009, 11:13:08 AM »
Absolutely sick, my friend, just fantastic work. I can not thank you enough for sharing these, just stunning.
Can we see a final pic of the last one with the stone mounted?
« Reply #151 on: August 12, 2009, 02:46:03 PM »
yup will do. will be next week some time
« Reply #152 on: August 12, 2009, 11:21:02 PM »
some back from setting and others out on their way.
im enjoying my mill.. makes life jsut that bit easier.
« Reply #153 on: August 13, 2009, 04:15:58 AM »
first time i ever cut metal... my nerves were shot.. even tho its only aluminum..
hogged out bulk on my lathe then wrote rest of path to trin and cut concentrically to my own mill. i made a startling discovery.. metal is not wax.. its noisy and its messy...
oh yeah its a new idea for a key for myself for flip+rotary parts.
« Reply #154 on: August 14, 2009, 08:27:14 PM »
this back in.
« Reply #155 on: August 15, 2009, 07:05:47 AM »
Neat, Chris, what's the black material for wearing around the neck made of/called?
« Reply #156 on: August 15, 2009, 03:50:55 PM »
neoprene :)
« Reply #157 on: August 15, 2009, 04:01:34 PM »
Chris, you do some great work.  :)
« Reply #158 on: August 16, 2009, 01:21:45 AM »
been making more fixtures...  this one locks up a model after three sided cutting so i can cut away the inner supports.
(note: the hub id off centre.. i screwed up the path but i think you get the idea.)
i tried to use the cut circle wizard in Mach but it seems locked to IPM and inches for size not mm, even tho my mach is set to use mm. ??
i put in 50 as a plunge unit and it shot down to my model at super speed, so im guessing its 50 IPM not 50mm/min?  i have no way to tell from the wizard what the units are.
ended up coding a circle cut so i can trust it.
« Last Edit: August 16, 2009, 01:24:30 AM by Chris.Botha »
« Reply #159 on: August 16, 2009, 01:22:26 AM »
center of the hub is set as offset in mach.
« Last Edit: August 16, 2009, 01:26:32 AM by Chris.Botha »
