Hello Guest it is November 04, 2026, 02:07:39 PM
Author Topic: Problems threading on the lathe  (Read 1218088 times)
0 Members and 6 Guests are viewing this topic.
Re: Problems threading on the lathe
« Reply #20 on: September 26, 2008, 09:48:13 PM »
smooth stepper landed today , the first one had male db25 and plugged right into my c11 BOB , This one came with female db25 on the cables, will have to figure something out in the morning to plug it into the c11 BOB on the lathe.
Brett and Hood stay tuned, many stupid questions to follow
« Reply #21 on: September 29, 2008, 10:27:56 PM »
Hey RT,
Would you mind to check this for me ?
http://www.machsupport.com/forum/index.php?topic=8461.new#new
If this is the screen that you are using.
RC
Offline Rieks
  •  26 26
« Reply #22 on: February 22, 2009, 03:23:11 PM »
Hello all,
While treading on the lathe, the x-axis is walking slow in or out on some cuts :o ???.
Can some one tel me what the solution is?
Rieks
« Reply #23 on: February 22, 2009, 03:53:57 PM »
What is the code you are using?
« Reply #24 on: February 22, 2009, 06:22:50 PM »
What version of MACH are you using?
How are you generating the threading code? Wizard, M76, G32?
What is the condition of your lathe?
- Ball screws / steppers / backlash ?
What are you using for an index?
Offline Rieks
  •  26 26
« Reply #25 on: February 23, 2009, 07:29:38 AM »
Hello,
The version I use is R3.042.020 and I use the wizard "Threading" in Lathe, thus G76
« Reply #26 on: February 23, 2009, 07:32:50 AM »
and what is the code that gives you the problem?
Offline Rieks
  •  26 26
« Reply #27 on: February 23, 2009, 09:30:23 AM »
When treading, after 2 or 3 cuts, wit  a depth of 0.2 mm, befor the next Z-axis movement in negativ
direction, the X-axis feeds in 0.2 mm, and then, when Z-axis moves in, the X-axis moves slowly out, as if
a taper is cut.
Rieks
« Reply #28 on: February 23, 2009, 09:47:03 AM »
please give an example of the problem code.
Offline Rieks
  •  26 26
« Reply #29 on: February 25, 2009, 02:28:13 PM »
Hello Hood,
sorry for the delay, Here is the problem code.
It is the first time I tested the threading wizard.
Rieks
