Hello Guest it is November 19, 2026, 08:47:34 AM
Author Topic: USB JoyPad and game device plugin - New Version 2.0  (Read 705957 times)
Offline kvid
  •  25 25
Re: USB JoyPad and game device plugin - New Version 2.0
« Reply #230 on: April 21, 2019, 04:18:28 PM »
Can someone please share the latest version of the plugin?
« Reply #231 on: June 13, 2019, 02:15:46 PM »
Thanks!
I have donated and am looking forward to getting the plugin
« Reply #232 on: June 25, 2019, 03:27:39 PM »
Is there any configuration for the plugin to jog both 6 axis with one Joypad (not simultaneously) with different buttons for every axis??
« Reply #233 on: July 10, 2019, 09:05:17 AM »
TOTAL noob here, would like to donate and get the pugin. Link please?
« Reply #234 on: November 13, 2019, 10:03:14 AM »
Is there a way to move rapidly (like when you press the shift key) by holding the SL and SR keys and just jog if only one of the latter safety keys is pressed? Same thing for the Z axis, obviously.
Thanks..
  •  9,378 9,378
« Reply #235 on: November 14, 2019, 12:16:25 AM »
Thanks..
From the TAB key flyout increase the Slow Jog Rate to 100% (or a figure that you are happy with).
« Reply #236 on: November 14, 2019, 05:22:36 AM »
Thanks..
Thanks, but I was looking to accomplish this without having to interact with my computer, thus without affecting the slow jog speed. I was planning to use both the keyboard and the joypad, so if I changed this value then I would have to reset it afterwards when using the keyboard which is kind of annoying.
  •  9,378 9,378
« Reply #237 on: November 14, 2019, 05:51:16 AM »
The keyboard jog keys have ASCII values of;
left 37, up 38, right 39, down 40, pageup 33, pagedown 34   if you add 1024 to these values that makes them the same as shift+key.
Can you re-configure your joypad with the revised values ?
« Last Edit: November 14, 2019, 05:55:06 AM by Tweakie.CNC »
« Reply #238 on: November 14, 2019, 07:58:39 AM »
As far as I know, you can't change the behavior of the thumb joystick. It's hardcoded, isn't it?. You can only change the scaling of the X and Y axes by changing the plugin config on Mach3.
« Reply #239 on: February 11, 2020, 08:18:13 PM »
Hi I'm a hobbyist miller and I'm new in the forum. I apologize in advance for my English ........
I installed the plug-in for joy-pad on my self-built cnc, it works very well but I have a problem ..... when I turn on the spindle the joy is deactivated and I have to disconnect and reconnect the USB socket to turn it back on. so every time i launch a g-code i have to do this. does it depend on some setting or is it something more serious?
i work with old pc with windows xp, connected to the milling machine through the parallel port
as hardware I have a 4-axis sainsmart tb 6560 controller and a 1.5 kw liquid cooled spindle driven by a "Chinese" inverter controlled with a 0-10 volt home made pcb. Can anyone please help me?
