Hello Guest it is October 27, 2026, 11:00:09 AM
Author Topic: Gertrude Gets Some!  (Read 719649 times)
  •  9,375 9,375
« Reply #230 on: March 05, 2010, 06:36:53 AM »
Still you have to look at it this way - the cutters from China are cheapy cheapy and the more you break the more mouths you feed. Its called doing your small bit for the emerging nations.  ;D
« Reply #231 on: March 05, 2010, 02:55:08 PM »
That's one way of looking at it I guess.  8)  The cutters might be cheap, but all the wax I've seen, is pretty pricey. How much did you contaminate Chris? Any way to get it separated? Maybe heat it up really hot and let the heavy stuff settle? Small screen?
« Reply #232 on: March 07, 2010, 08:13:27 PM »
lol.
after i did this i posted on 3dcadjewelery too and a very important bit of information came to light.. metal is heavier than wax, so only the very bottom of the remelt will be affected, so new system in place. melt once, shave bottom off, remelt again!
« Reply #233 on: March 10, 2010, 03:18:20 PM »
another signet..
« Reply #234 on: March 11, 2010, 02:40:55 AM »
mirror of a post on 3dcad forum about when arcfitting will bite your ass...
well.. blow me down.. I learned something today.. arc fitting can sometimes work against you!
on low gradual surfaces the arc fitted code resulted in a VERY stripey cut, and i was waaaaaaaay dissapointed.. I had to recut anyhow as the wax came out to thin, on the next cut i forgot to ARC fit my code and the resultant cut was infinitely better.. it did show some stl facetting.. very minor tho in comparison to the distinct striping from the arcfitted code.
SAME STEPOVER, SAME TOOL, SAME STRATEGY, SAME SPEED.. only difference was the arcfitting.
ARCFITTED PATH
NON ARCFITTED PATH
Uploading a video clip to youtube now.
  •  9,375 9,375
« Reply #235 on: March 11, 2010, 07:00:04 AM »
Hey Chris,
Could you explain this a little more please. I am baffled.
It looks like the top photo has the toolpath running horizontal wheras the other photos look like the toolpath is vertical to the piece.
Surely if the stepover was the same then all phots would show the lines, wouldn't they ?.
« Reply #236 on: March 11, 2010, 01:34:18 PM »
the first cut was arcfitted, and the resulting arc was drawn over a perfectly spherical shape.. IE: one arc from left to right.. the bottom path was left as a sequence of XZ,XZ,XZ,XZ etc etc then one Y movement at each end. I have never had this happen before and i think the reason is exactly that the arc travels the complete distance of the piece.. the part was pathed at 0.005 path to model tolerance but the arc fitting happened at 0.01 tolerance arc to path, so some averaging of the resulting arc occurred.
note in top pic the line is perfectly smooth over X, no stl faccetting to be observed. perfect RC.
bottom one plenty evidence of facceting but no striping.
Im interested in testing this again. I also posted a clip o it
http://www.youtube.com/watch?v=UFDtLz3vblg
Offline N4NV
  •  398 398
« Reply #237 on: March 11, 2010, 08:28:16 PM »
What are you using for a spindle?  Watching your videos, it seems very quiet.
Vince
« Reply #238 on: March 11, 2010, 11:50:44 PM »
NSK 2530E and yes its whisper quiet :)
Offline BarryB
  •  267 267
« Reply #239 on: March 12, 2010, 09:00:55 AM »
What's the HP on a spindle like that?  I can tell you mine is la-oud!  I gotta wear hearing protection.  Is it only designed to work in soft materials like wax/resin?
Barry
