Hello
Guest
it is
September 30, 2026, 10:36:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
General CNC Chat
Show"N"Tell ( What you have made with your CNC machine.)
Gertrude Gets Some!
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
Go Down
Author
Topic: Gertrude Gets Some! (Read 713473 times)
budman68
2,352
Reply #150 on:
August 12, 2009, 11:13:08 AM »
Absolutely sick, my friend, just fantastic work. I can not thank you enough for sharing these, just stunning.
Can we see a final pic of the last one with the stone mounted?
Dave->
Chris.Botha
488
wine me.. dine me.. tram my mill for me...
Reply #151 on:
August 12, 2009, 02:46:03 PM »
yup will do. will be next week some time
http://www.facebook.com/pages/Melbourne-Australia/Digital-Jeweller/136490863976
Chris.Botha
488
Reply #152 on:
August 12, 2009, 11:21:02 PM »
some back from setting and others out on their way.
im enjoying my mill.. makes life jsut that bit easier.
Chris.Botha
488
Reply #153 on:
August 13, 2009, 04:15:58 AM »
first time i ever cut metal... my nerves were shot.. even tho its only aluminum..
hogged out bulk on my lathe then wrote rest of path to trin and cut concentrically to my own mill. i made a startling discovery.. metal is not wax.. its noisy and its messy...
oh yeah its a new idea for a key for myself for flip+rotary parts.
Chris.Botha
488
Reply #154 on:
August 14, 2009, 08:27:14 PM »
this back in.
budman68
2,352
Reply #155 on:
August 15, 2009, 07:05:47 AM »
Neat, Chris, what's the black material for wearing around the neck made of/called?
Dave->
Chris.Botha
488
Reply #156 on:
August 15, 2009, 03:50:55 PM »
neoprene
Chaoticone
5,624
Precision Chaos
Reply #157 on:
August 15, 2009, 04:01:34 PM »
Chris, you do some great work.
If you could see the things I have in my head, you would be laughing too.
Chris.Botha
488
Reply #158 on:
August 16, 2009, 01:21:45 AM »
been making more fixtures... this one locks up a model after three sided cutting so i can cut away the inner supports.
(note: the hub id off centre.. i screwed up the path but i think you get the idea.)
i tried to use the cut circle wizard in Mach but it seems locked to IPM and inches for size not mm, even tho my mach is set to use mm. ??
i put in 50 as a plunge unit and it shot down to my model at super speed, so im guessing its 50 IPM not 50mm/min? i have no way to tell from the wizard what the units are.
ended up coding a circle cut so i can trust it.
Last Edit: August 16, 2009, 01:24:30 AM by Chris.Botha
Chris.Botha
488
Reply #159 on:
August 16, 2009, 01:22:26 AM »
center of the hub is set as offset in mach.
Last Edit: August 16, 2009, 01:26:32 AM by Chris.Botha
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
Go Up
« previous
next »
