Hello Guest it is September 30, 2026, 10:35:09 PM
Author Topic: Gertrude Gets Some!  (Read 713471 times)
« Reply #290 on: July 20, 2010, 08:16:44 AM »
Atta boy, Chris!!!
At the first of June it was...."my wifes first multisided index job!"
Now it's...."my wife does all my milling... she does virtually all my pathing as well....can write a complex multipass multiangle path"
Now THAT'S what I call training. Nice job letting her know that she 'still ain't there yet' by complaining about layer colors. You can't let them get too sure of themselves, or they might start thinking they are closer to an equal, rather than an underling. The next time she's working on something, step in and change some tiny thing that don't even make sense. Of course she will say "why did you do that for?" Upon which you will reply some totally off the wall crap, that you make up in your head such as..."Because that's the way it has to be done. Otherwise, the tool used at that spindle speed, cutting WX-233 impregnated wax in a microdyne constorted fashion, would surly make a mess of things in a hurry. I won't even go into the other mistakes I see because we can live with them for now. The important thing is...your getting there, but there's still a looooong way to go"
Then you can walk off, and go finish watching how Shaggy and Scooby solve there latest mystery, or Meerkat Manor or something.
Awesome job, Chris.
« Reply #291 on: July 20, 2010, 02:59:48 PM »
mwaaaaaaaaaaaaaaaaaaaaaaaaaaaahahahahahahahhahahahahaha
good plan!
  •  9,374 9,374
« Reply #292 on: July 21, 2010, 01:11:38 AM »
I second that Chris.
Sam got me out of trouble once (the CBI) and he is a real expert.
« Reply #293 on: July 21, 2010, 06:19:14 AM »
http://www.youtube.com/watch?v=-rxwhEzLh7E
I tried to grab some wife milling action... but no go!
« Reply #294 on: July 24, 2010, 07:50:14 PM »
see i can do it myself too! 4 to 6 hour wait on rest of job will pot updates then ;)
Was going ot do a tut on this pathing but I am having trouble with periodic crashed so decided to doa step by step pictorial instead.
1: Setup huge wax block
2: Check X old fashoined way ;)
3: Run the roughing paths with a 3.17 EM
4: Cut the hole for Brant's arbor.
5: Start indexing path, this one includes all blockers in place and is low res at 0.05mm stepover.
6: Hide the side panel blocker and go in at 0.02 stepover
7: Cut the indexed taper ball areas at about 50 degrees
REPEAT 5 - 7 at A180 again.
8: Use paint to check that detail is ok before removing from mill.
9:Rotary phase1 , full cut at low res 0.05mm Blockers back in place.
10: which will be followed by three indexs at 290 - 0 - 70.
Keep fingers crossed rotary phase comes good, will edit and add pics after its done.
« Reply #295 on: July 25, 2010, 05:44:57 PM »
11: Time to decore that sucker
12: and get some sleep...
[/img][/quote]
« Reply #296 on: July 25, 2010, 06:05:44 PM »
HEY Chris, what happened to your hair.
Nice work, Jeff.
You should make another video of your work, was very interested.
« Reply #298 on: July 27, 2010, 03:08:36 PM »
and some vids on the pathing
Pathing the ring PART 1
http://www.youtube.com/watch?v=hRnFOA1a7pU
Pathing the Ring PART2
http://www.youtube.com/watch?v=o5QVKt2i_SU
Regards
Chris Botha
« Reply #299 on: August 01, 2010, 04:49:16 PM »
for this job.. well, all i am going to say is thank goodness wifey is running the mill. good strategy girl.
