Hello Guest it is November 04, 2026, 01:11:30 PM
Author Topic: Problems threading on the lathe  (Read 1218011 times)
Offline lemo
  •  135 135
Re: Problems threading on the lathe
« Reply #370 on: May 26, 2009, 09:27:14 AM »
I thought the profiles are calculated on the fly. If they are not, then that explains everything. I understand that it will make the gantry fly of the table if someone would enter 1000% ;).
Also the use of different feed speeds for approach and things alike makes it even worse. The approach speeds are low already and setting things to 50% is making that a crawl and hot running tools. If the 50% rule should be used, then there would have to be several F1, F2,F3 etc.... which then would need weighted factors. of course that would now make a complete mess out of the problem lol.
Rainer
Cut five times and still to short...
« Reply #371 on: May 26, 2009, 10:29:07 AM »
I have moved the computer to the rear of the machine and have a usb cable only a foot long between the computer and SS and I am still losing comm with SS every 5 minutes or so  . I just cant think of any other variables to try
« Reply #372 on: May 26, 2009, 10:41:51 AM »
I dont know if this helps but when i reboot the computer I have to unplug and replug the USB going to SS before mach will communicate with it.
« Reply #373 on: May 26, 2009, 12:22:45 PM »
Try going into device manager and see if you can rollback the driver for the SS.
« Reply #374 on: May 26, 2009, 12:24:59 PM »
I have done a complete format on both computers as of yesterday so everything before yesterday is gone
« Reply #375 on: May 26, 2009, 12:30:39 PM »
Did you use the same download of Mach, SS Drivers and SS Plugin on them, might be one or all of these are corrupt, try downloading each again.
« Reply #376 on: May 26, 2009, 01:22:24 PM »
downloaded everything fresh and attempting to instal. Now I get a message when I plug the SS in that says unrecognized USB device . Uninstal driver and run new hardware wizard to re-instal driver and I get a message stating there is no better driver than the one already installed.
« Reply #377 on: May 26, 2009, 01:29:51 PM »
Try using FTClean to wipe out all traces of the drivers then reinstal.
http://www.ftdichip.com/Resources/Utilities/FTClean.zip
« Reply #378 on: May 26, 2009, 01:48:31 PM »
ran ftclean , replugged the ss , same problem just says its an unknown usb device and cant instal the driver , keep getting the no better driver for your hardware message.
« Reply #379 on: May 26, 2009, 01:51:35 PM »
Sounds like your USB Hubs are screwed in windows, try deleting them in device manager then restarting and letting windows reinstall the drivers.
Just another thought, make sure you have the jumper for power set the right way on the SS, may be you are trying to power from USB but its set for external or vice versa.
