Hello Guest it is November 04, 2026, 01:08:09 PM
Author Topic: Problems threading on the lathe  (Read 1217992 times)
0 Members and 6 Guests are viewing this topic.
Re: Problems threading on the lathe
« Reply #350 on: May 25, 2009, 07:21:51 AM »
control freq is set to1khz, 500mhz on the x and z axis , spindle and all others are set to 256
in monitering the only thig flagged is a check box labled "is still"
not sure where the time out setting is , maybe thats my problem
« Last Edit: May 25, 2009, 07:31:29 AM by panaceabeachbum »
« Reply #351 on: May 25, 2009, 07:41:02 AM »
should be on the config page if you have the latest plugin, its called Watchdog.
I would set the axis that arent being used to 32KHz and presume you are meaning 512KHz rather than MHz but whatever it is just set to the setting just above what you actually need.
« Reply #352 on: May 25, 2009, 07:43:31 AM »
Also, the message you get does it say something about it will be handled more elegantly in the future or words to that effect? If so try unplugging your keyboard and seeing if that helps.
« Reply #353 on: May 25, 2009, 08:27:30 AM »
I am not finding anything labled watchdog , I downloaded and installed the latest plugin yesterday , its labled as  vo15ogb.
here is the message I get
« Reply #354 on: May 25, 2009, 08:38:48 AM »
Ah ok thats not the message I was meaning so diregard the keyboard thing.
Watchdog should be in the latest plugin, maybe its called something different, I have a Beta.
« Reply #355 on: May 25, 2009, 09:46:01 AM »
thanks Hood, I see the watchdog now , same problem . I have to load a job in the big Haas mill but as soon as its up and running I will be swapping out the computer  in the troublesome lathe
« Reply #356 on: May 25, 2009, 11:25:09 AM »
may be speaking to soon but so far all looks well.
I was pulling the computer out of the cabinet at the front of the machine and noticed I had neglected to disconnect the two 12 foot long PP cables that run to the cabinet at the back of the machine. I detached them form the PC and have been running for a little over an hour with no problems yet , maybe they were acting as a big antenna. Will feel foolish (and happy) if it was something so simple
Will be running it for the next 8-10 hours threading hundreds of suppressor end caps
« Reply #357 on: May 25, 2009, 01:23:29 PM »
Sounds like that is quite possible, lets hope so :)
« Reply #358 on: May 25, 2009, 03:15:57 PM »
had a pretty good run, got about 85 parts turned and threaded before it lost touch with the SS this time. Now its back to dropping the connection about every 5 minutes . Going to try the other computer
« Reply #359 on: May 25, 2009, 04:22:15 PM »
I installed a different computer , complete format , latest version of mach, latest plugin and SS driver and its losing contact with the smooth stepper within 3-4 minutes , same issue . Not much left to swap .
Vfd is no where near computer , bob or drives , everything is properly grounded .  I dont know if its an issue or not but the usb cable from the computer to the SS is about 10 feet long
 Any thoughts appreciated
« Last Edit: May 25, 2009, 04:25:15 PM by panaceabeachbum »
