Hello
Guest
it is
November 13, 2026, 02:42:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Newbie to cnc building in need of some help please
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
Go Down
Author
Topic: Newbie to cnc building in need of some help please (Read 73827 times)
TPS
2,627
Re: Newbie to cnc building in need of some help please
Reply #30 on:
January 20, 2019, 09:34:25 AM »
just to confirm:
-Settings -> Port's&Pin's -> Port Setup and axis selection -> Port 1 is enabled
-Settings -> Port's&Pin's -> Port Setup and axis selection -> Port 1 adress is set correctly
-Settings -> Port's&Pin's -> Motor Outputs -> axis is enabled
-Settings -> Port's&Pin's -> Motor Outputs -> Step Pin , Dir Pin and port are correct
scooternauman
41
Reply #31 on:
January 20, 2019, 09:43:59 AM »
port 1 is enabled. port address is in question. axis is enabled. I'm pretty sure i have pins and ports correct. x=2,3 y=4,5 z=6,7
if i go into my control panel I'm not sure what I'm looking for.
scooternauman
41
Reply #32 on:
January 20, 2019, 09:46:06 AM »
when i click on devices in my control panel all it shows is a microsoft xps document writer and I'm not sure why that is
TPS
2,627
Reply #33 on:
January 20, 2019, 09:50:24 AM »
sorry have only a german version
scooternauman
41
Reply #34 on:
January 20, 2019, 09:57:43 AM »
lol I wish I knew what that said. However the only devices shown connected in my control panel are wifi adapter , keyboard,moniter, pc and mouse.
I deleted the document writer because there is none.
TPS
2,627
Reply #35 on:
January 20, 2019, 10:02:24 AM »
but you said, you run drivertest succesfuly?
scooternauman
41
Reply #36 on:
January 20, 2019, 10:03:15 AM »
that is correct
scooternauman
41
Reply #37 on:
January 20, 2019, 10:04:16 AM »
just ran it again and it says system excellent
TPS
2,627
Reply #38 on:
January 20, 2019, 10:06:10 AM »
can't run drivertest here (64Bit), is there any port adresss shown?
scooternauman
41
Reply #39 on:
January 20, 2019, 10:07:40 AM »
no port shown
Print
Pages:
1
2
3
4
5
6
7
Go Up
« previous
next »
