Hello Guest it is November 13, 2026, 02:03:09 PM
Author Topic: Newbie to cnc building in need of some help please  (Read 73808 times)
Re: Newbie to cnc building in need of some help please
« Reply #20 on: January 20, 2019, 08:59:03 AM »
let me switch my a+ a- b+ b- to match what you sent and see if that does anything. I the link you shared enable as not connected.
Offline TPS
  •  2,627 2,627
« Reply #21 on: January 20, 2019, 09:03:35 AM »
see attached
« Reply #22 on: January 20, 2019, 09:07:14 AM »
YAY! Little victories. By switching my A's and B's  I can no longer turn ball screws by hand. Still no movement of axis's though.  Enable+ huh? Let me run some quick jumpers.
« Reply #23 on: January 20, 2019, 09:19:52 AM »
OK so, I ran jumpers from my +5 volt to the Enable + on each drive. I have a powerful hold on my ball screws but still no movement of any axis.
Offline TPS
  •  2,627 2,627
« Reply #24 on: January 20, 2019, 09:23:26 AM »
due searching for a Manual for your breakout bord, there seam to be different Versions.
do you have this Version, with the jumper's,
and are both jumper's set ?
Offline TPS
  •  2,627 2,627
« Reply #25 on: January 20, 2019, 09:26:08 AM »
btw are your axis dro's changing if you try to jog?
« Reply #26 on: January 20, 2019, 09:27:03 AM »
Yes that is the board I have and both jumpers are jumped.
« Reply #27 on: January 20, 2019, 09:29:00 AM »
yes the DRO's are showing movement in + and - directions
Offline TPS
  •  2,627 2,627
« Reply #28 on: January 20, 2019, 09:29:45 AM »
i assume you are using the Standard 1024 sceenset.
is the reset button permanent green or flashing ?
« Reply #29 on: January 20, 2019, 09:31:48 AM »
permanent green if I disable the ESTOP. Constant flashing when I set ESTOP port to =1
