Hello Guest it is September 30, 2026, 04:04:04 AM
Author Topic: Newbie to cnc building in need of some help please  (Read 71119 times)
Re: Newbie to cnc building in need of some help please
« Reply #60 on: January 20, 2019, 01:05:28 PM »
same thing happens with p2 to ground and p4 to ground so it would appear the controllers are fine?
Offline TPS
  •  2,627 2,627
« Reply #61 on: January 20, 2019, 01:10:02 PM »
yes that means all Motor Controllers are working.
i would now Z axis P6/P7 as shown in my Video
step- and dir- to GND
step+ to P6
dir+ to P7
that is one of the last ideas now
don't Forget to Setup p6/p7 in Port's&pin's
« Reply #62 on: January 20, 2019, 01:39:51 PM »
I'm not sure about the ground idea.
this is how I am wired and it matches the schematic you linked earlier
x axis=
PUL+ to  5 volt power supply
PUL-  to  P2
DIR+ to  5 volt power supply
DIR-  to  P3
ENABLE to 5 volt power supply
Y axis=
PUL-  to  P4
DIR-  to  P5
Z axis=
PUL-  to  P6
DIR-  to  P7
Offline TPS
  •  2,627 2,627
« Reply #63 on: January 20, 2019, 02:46:54 PM »
i mean how it was shown in the two Videos
PUL+ to  P2
PUL-  to  GND
DIR+ to  P3
DIR-  to  GND
and so on
i am out for today, it is getting late here.
« Reply #64 on: January 20, 2019, 03:27:04 PM »
Hey thanks again for all your help. Progress was made. Have a great evening.
 I just tried wiring with a common ground as shown in the videos.
Still no movement from motors.
TTYL
Offline TPS
  •  2,627 2,627
« Reply #65 on: January 21, 2019, 01:44:01 AM »
somethings amiss here.
p2 on the breakout board is a steady 1.58 volts in both directions.
p4 is at 1.54 in both dir
so it seems there might be an issue with p2 and p4?
here you can a test of the 25pol cable to make sure that P2 and P4 are connected here.
and for additional testing i think a oszlisocope is needed to check P2,P4 and P6 that there
a pulse stream is created.
« Reply #66 on: January 21, 2019, 03:57:48 AM »
So I wanted to rerun the testing of the pins on the drive side before work this morning. It appears I had something wrong the first time.
All pins 2-9 are acting as they should. 5.12 volts in the "on" dir. and 1.1 volts in the "off" dir.
I tested all pins twice.
Once with the drives disconnected.
Once with the drives connected.
Same results both times.
Off to work I go.
TTYL
