Hello Guest it is November 13, 2026, 01:30:28 PM
Author Topic: Newbie to cnc building in need of some help please  (Read 73796 times)
Offline TPS
  •  2,627 2,627
Re: Newbie to cnc building in need of some help please
« Reply #10 on: January 20, 2019, 08:07:37 AM »
anyway i think both solution should work(but not sure).
even here : https://www.youtube.com/watch?v=uN7VospeGN0
is an other one with common GND wiring.
if you Switch everything on, do you have Holding torque at your Motors?
« Last Edit: January 20, 2019, 08:13:51 AM by TPS »
« Reply #11 on: January 20, 2019, 08:22:41 AM »
When everything is powered on i can feel some pull on the ball screws but i can still turn them by hand. It just feels different when powered on.
Offline TPS
  •  2,627 2,627
« Reply #12 on: January 20, 2019, 08:28:19 AM »
what Motors do you exactly have?
how are dip switches (SW1-SW3) set on the Motor Controller?
« Reply #13 on: January 20, 2019, 08:31:30 AM »
I have the longs 425 oz stepper motors. p1=off p2=on p3=off. the only others on are 6,7,8
Offline TPS
  •  2,627 2,627
« Reply #14 on: January 20, 2019, 08:35:13 AM »
ok the Switches are set to 2.36A, i think then you should not able do turn the Motor easily by Hand.
where is the enable of the Driver wired too?
Offline TPS
  •  2,627 2,627
« Reply #15 on: January 20, 2019, 08:38:52 AM »
for the Motor wiring:
A+ black
A- green
B+ red
B- blue
« Reply #16 on: January 20, 2019, 08:44:00 AM »
The drivers are DM542A with a max peak of 4.2A. According to some papers I found online with 1,2,3 off= 4.2A. So I just switched to mach. Can still turn by hand. My enable is not wired at all (just like in the video I shared.) My PUL+(+5v) and DIR+(+5v) are wired to the +5 volt side of my terminal block(as in the video)
« Reply #17 on: January 20, 2019, 08:49:56 AM »
I have
   red=a+
green=a-
 black=B+
  blue=B-
Offline TPS
  •  2,627 2,627
« Reply #18 on: January 20, 2019, 08:50:04 AM »
according to this Manual:
http://fablab.web-5.org/lib/exe/fetch.php/documentation:drivers_mpp:dm542a-manuel-20130925.pdf
i do not think you can leave enbl+ unconnected.
make a quick Connection to 5V just to be sure.
Offline TPS
  •  2,627 2,627
« Reply #19 on: January 20, 2019, 08:51:40 AM »
« Last Edit: January 20, 2019, 08:57:51 AM by TPS »
