Hello Guest it is November 13, 2026, 01:54:11 PM
Author Topic: Newbie to cnc building in need of some help please  (Read 73806 times)
Offline TPS
  •  2,627 2,627
Re: Newbie to cnc building in need of some help please
« Reply #30 on: January 20, 2019, 09:34:25 AM »
just to confirm:
-Settings -> Port's&Pin's -> Port Setup and axis selection -> Port 1 is enabled
-Settings -> Port's&Pin's -> Port Setup and axis selection -> Port 1 adress is set correctly
-Settings -> Port's&Pin's -> Motor Outputs -> axis is enabled
-Settings -> Port's&Pin's -> Motor Outputs -> Step Pin , Dir Pin and port are correct
« Reply #31 on: January 20, 2019, 09:43:59 AM »
port 1 is enabled. port address is in question. axis is enabled. I'm pretty sure i have pins and ports correct. x=2,3 y=4,5 z=6,7
if i go into my control panel I'm not sure what I'm looking for.
« Reply #32 on: January 20, 2019, 09:46:06 AM »
when i click on devices in my control panel all it shows is a microsoft xps document writer and I'm not sure why that is
Offline TPS
  •  2,627 2,627
« Reply #33 on: January 20, 2019, 09:50:24 AM »
sorry have only a german version
« Reply #34 on: January 20, 2019, 09:57:43 AM »
lol I wish I knew what that said. However the only devices shown connected in my control panel are wifi adapter , keyboard,moniter, pc and mouse.
I deleted the document writer because there is none.
Offline TPS
  •  2,627 2,627
« Reply #35 on: January 20, 2019, 10:02:24 AM »
but you said, you run drivertest succesfuly?
« Reply #36 on: January 20, 2019, 10:03:15 AM »
that is correct
« Reply #37 on: January 20, 2019, 10:04:16 AM »
just ran it again and it says system excellent
Offline TPS
  •  2,627 2,627
« Reply #38 on: January 20, 2019, 10:06:10 AM »
can't run drivertest here (64Bit), is there any port adresss shown?
« Reply #39 on: January 20, 2019, 10:07:40 AM »
no port shown
