Hello Guest it is November 03, 2026, 07:03:16 AM
Author Topic: BT30 spindle from scratch - with power drawbar and ATC of course  (Read 1315918 times)
« Reply #170 on: September 23, 2012, 10:29:13 AM »
Poking around for BT30 stuff and came across this complete spindle and actuator. Good comp.
http://www.ebay.com/itm/BT-30-8-000-RPM-SPINDLE-with-AIR-CYLINDER-ASSEMBLY-/300743758615?pt=LH_DefaultDomain_0&hash=item4605b99317
DWalsh: caution about posting drawings . . . the teacher has a big RED pencil  . . .  a corner chair with dunce cap . . .  and possibly a wooden ruler  . .  and a paddle  :o
Now that is interesting/funny but I produced this spindle for Greg Heyen of Servo Products Co. LTD, the hybrid pneumatic/hydraulic cylinder I get out of China and comes assembled with the switches, valves and other parts as pictured for cheaper shipped than I can buy the parts in the USA.
« Reply #171 on: September 23, 2012, 12:32:18 PM »
 The cylinder is 45mm OD. I took a couple of pics so you could see the setup closer, springs are not that strong and I managed to push them down fairly easily with the palm of my hand.
« Reply #172 on: September 23, 2012, 01:02:19 PM »
Just for your amusement, here is the current state of my ATC - I finally got some time to work on it yesterday.  It's mounted on the machine, and, operating it manually, it appears to work perfectly - the forks slide on and off the tools very nicely, and the tools slip in and out of the spindle effortlessly.  I hope in the next few days to get the top plate of the housing done, which will let me mount the geneva motor, and see how that all works under power.  Then, it's just a matter of mounting the two air cylinders - one long one to swing the ATC to the spindle, and back to the park position behind the table, and the second to push the carousel down for ejecting tools from the spindle.  I'll also need to re-make my Y/Z way cover, to make it narrower so the ATC can get back as far as possible when parked, and re-make my coolant "collar", which right now mounts to the bottom of the spindle, and interferes with the ATC.
« Reply #173 on: September 23, 2012, 01:10:32 PM »
Mr.Hood, thanks SO much! Looks like I was in the ball park with my WAG. This morning I ordered materials to make the pods and the carousel. Now I can get the springs and other hardware bits on order.
Curiosity, are you going to buy the mill?
« Reply #174 on: September 23, 2012, 01:29:01 PM »
Well, if I am to be amused, I must get out my RED pencil  >:D . . . kidding, of course. Your work is always first class and logically conceived.
Interesting thing is that what you have is something of a hybrid between the typical moving carousel arrangements that I have seen and with what I am doing. You move the carousel . .  so far fairly conventional . . . .  but as always there is the 'Kabibble Twist' on it. You move it with an arm! That removes one of my objections to the travelling carousel concept . .  that being the carousel hanging over the table. This is the first arrangement I have seen with an arm swinging the carousel. Very clever indeed.
Couple questions if you don't mind (not to worry no RED pencil here);
1) Another of my quibbles with the DIY setups is lack of protection for the taper (or 'stud' I suppose in your case). Do you have any plan to protect those surfaces from swarf?  Do you consider that a must have or optional?
2) What kind of sensors are you planning? At what points in the process do you recon a confirmation is required before moving to the next step?
3) Probably you would get around to this eventually, but I am impatient so . . what will drive the Geneva?
4) did you make the holders in the carousel or are they a Tormach part?
5) Will you use a sparate PLC to control the sequencing or will it be integrated into your Kflop system?
6) How do you do the thumbnail - to - full size photos?
« Last Edit: September 23, 2012, 01:45:34 PM by simpson36 »
« Reply #175 on: September 23, 2012, 01:55:04 PM »
Yes, decided to go for it, started a thread in the Show and Tell, looks a bit grubby but I suppose for a 1987 machine its not too bad. Mechanical wise it seems fine and really thats all I am worried about.
« Reply #176 on: September 23, 2012, 02:07:23 PM »
Do you really see anything wrong with that drawing?
It's almost a copy of the Okuma BT30 spindle minus some features to make it cost affordable to produce and sell for a reasonable price.
I sell the BT30 spindle with matching cylinder to Servo Products for $1600.00 delivered (they are less than 15 minutes away from me).
The BT15 spindle is a work of art internally, a magnetically activated internal coolant/air valve for coolant through spindle and blowout (put a magnet on the body in one of two places and it activates the valve), PTFE high pressure seals and 60,000RPM P42 (JIS class 4 dimensional accuracy with JIS class 2 running accuracy) NTN sealed 25 degree angular contact bearing (not cheap) are all hidden inside so externally it doesn't look like much, I've made changes to the design and moved the disc springs internal without sacrificing anything so it now looks like the traditional cartridge and I should have 10 assembled in the next two or three weeks, maybe a little longer if NTN doesn't deliver the bearings on schedule.
« Reply #177 on: September 23, 2012, 02:12:27 PM »
Nice piece of work Ray, well thought out and implemented.
« Reply #178 on: September 23, 2012, 02:15:44 PM »
Quote from: HimyKabibble
Yes, the carousel will be enclosed (a circular top cover, and 4" high side covering, so the tool holders are completely enclosed top and sides, with only longer tools exposed.  There will be a rotating door to uncover the selected tool, operated by a simple cable as the carousel swings into position.  I think this, alone, will suffice for keeping crud away from the tool holders.  If not, it will be easy to rig a Plexi or sheet metal shield between the back of the table and the front of the carousel when it's parked.
I haven't worked out all the details, but I will be using a combination of microswitches and Hall sensors.  Switches will be used to ensure the arm moves to both extremes of motion.  This will allow me to stop operation if the arm jams for any reason.  Also to ensure the carousel "lift" mechanism moves full travel, so I can stop operation if the tool does not move fully into, or out of, the spindle.  There are Hall sensors on the Geneva to indicate it is "in position", and also one to indicate it is positioned at tool 1.  This will allow me to "home" the carousel, and track position during moves.  I also expect to have a hall sensor to detect a toolholder  is present in the selected position, so I can tell that it correctly was loaded into the spindle, or extracted from the spindle before proceding.  I think that should be enough....
The Geneva is driven by a simple DC gearmotor, about $35 from McMaster.  I hope to have that mounted and working no later than tomorrow.  I did prototype it a few months ago, and it worked perfectly - very smooth and quiet, and very precise positioning, with near zero torque required to rotate it.  The motor I'm using is not blindingly fast, but adequate - about 1 second per tool.  This should make the worst-case toolchange time maybe 15 seconds,. and the more typical (sequential) probably under 10 seconds.
Made my own, though they are very similar to the Tormach (kinda have to be....).  They're cheap and easy to make, and a designed-in failure point in case of a jam.  They're attached with #10 Nylon screws, so a jam should simply rip the fork off the carousel, breaking only the screws.  Note that I could very easily fabricate a new carousel disc, and tool forks (no more than half a day's work), and switch the whole thing over to 30-taper.  No other changes should be required, other than perhaps extending the vertical travel of the carousel, which would just mean swapping out the air cylinder.
Sequencing will be controlled entirely by the KFlop for now.  Until I run out of I/Os (and I'm not that far....), there's really no reason to do otherwise.  Once it's working, moving the functionality to a dedicated micro would be really trivial, and I'd probably just go to a simple RS232/RS485 serial interface (as I'm already doing on my pendant).
I don't....  I just attach the photos using the built-in function on the forum.
« Last Edit: September 23, 2012, 02:17:17 PM by HimyKabibble »
« Reply #179 on: September 23, 2012, 02:37:07 PM »
Not at all. Just a joke based on the guys tauting me a few posts back. BR was the actual target, in a sense. I assumed you had read thru there and would get the tease. First rule of plumbing and so on. Sorry it was unclear. No offense intended.   :-X
« Last Edit: September 23, 2012, 02:43:38 PM by simpson36 »
