Hello
Guest
it is
November 22, 2026, 03:33:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Mach 4 Feature Request
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
Go Down
Author
Topic: Mach 4 Feature Request (Read 744512 times)
BR549
6,965
Re: Mach 4 Feature Request
Reply #60 on:
May 14, 2014, 11:27:19 PM »
An Email alert would be nice.
In Mach3 we have an "email alert" (M3 call home) that emails you on ERROR or Program end.
Just a thought, (;-) TP
BR549
6,965
Reply #61 on:
May 14, 2014, 11:29:39 PM »
A Load file from picture is nice at times. That is also a working Mach3 function that works VERY well with Sheetcam.
BR549
6,965
Reply #62 on:
May 14, 2014, 11:34:57 PM »
A function for printing the tool table and fixture table. OR just Export the table to a text file THEN we can print it in notepad from there. also the Test file could be imported into you CAM program.
Also an import function to import tool tables from CAM
Those are working Mach3 functions as well.
BR549
6,965
Reply #63 on:
May 15, 2014, 10:40:43 AM »
HIYA Steve just so you know that I am not pulling on your leg here is a picture of the tool table and you can SEE it does have an entry for the Slot#. Then IF it has a value will link the Slot# to the Tool# without having to physically swap the tool and UPdate the values all the time.
Easy Peasy, (;-)TP
swarfboy
71
Reply #64 on:
May 17, 2014, 10:20:34 AM »
Mach 4 is missing "A-rotations enabled" so that rotary toolpaths can be properly backplot in the toolpath viewer.
swarfboy
71
Reply #65 on:
May 17, 2014, 10:26:04 AM »
"CV distance tolerance" and "stop CV on angles >" parameters are missing from mach4
ger21
6,295
Reply #66 on:
May 18, 2014, 09:50:48 AM »
Any chance of allowing DRO's to be on top of the toolpath, or somehow embedded in the toolpath window?
BR549
6,965
Reply #67 on:
May 18, 2014, 02:02:55 PM »
Long ago Brian send down a screenset to test for Mach3 that HAD the xyza dros imbedded in the toolpath display, so I know it is possible, But will we get it Mach4 ??
shad71
33
Reply #68 on:
May 18, 2014, 03:28:48 PM »
It would be great if will add three very important functions for plasma cutting system.
1. Switch off possibility of THC Automatic voltage control (AVC) on the end of cut and set the distanse to the end of cut.
2. Switch off AVC just before corner and switch it On after passing the corner.
3. Switch off AVC on holes with small radius.
For both function add software bool variable in Mach4 variables, for example bool THC_AVC and then if(THC_AVC == false) disable AVC else enable AVC
Thanks!
--Andrew
BR549
6,965
Reply #69 on:
May 18, 2014, 04:37:52 PM »
Those are Plasma functions that should be controlled at the CAM side. The machine side is just suppose to follow the gcode BUT without pauses in motion when Mcodes does switching.
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
Go Up
« previous
next »
