Hello Guest it is October 30, 2026, 10:39:42 PM
Author Topic: A new Huanyang VFD plugin  (Read 516196 times)
Offline swets
  •  52 52
  • www.arjan-swets.com
Re: A new Huanyang VFD plugin
« Reply #170 on: August 19, 2017, 01:57:54 PM »
I want to try this plugin, but I get a :  Plugin DLL Defective.Reload.
what does it mean?  and what todo about it?
« Reply #171 on: August 19, 2017, 01:58:38 PM »
Delete the plugin from you plugins folder, and try downloading a new copy of it.
Offline swets
  •  52 52
« Reply #172 on: August 19, 2017, 02:05:18 PM »
Did that al ready.... din't help?
« Reply #173 on: February 23, 2018, 08:22:08 PM »
Make sure you include a ground between the pc and the VFD (DCM on terminal strip) otherwise the process may not work.
« Reply #174 on: January 10, 2019, 06:53:45 PM »
Hi has anyone used this plug in with Windows 10? Need to do anything special to get it going?
Offline Chaz
  •  48 48
« Reply #175 on: January 11, 2019, 01:35:22 AM »
Yes with Win10 and no, dont recall needing to do anything different.
« Reply #176 on: April 28, 2019, 06:01:19 AM »
I modified the 1.7.1 version of the plugin a bit so that it sets RTS high when sending, and otherwise keeps RTS low for receiving, so that it behaves with dummy RS485 converters.
It's a quick hack, and I'm not sure if royaumedeole would approve releasing this, but if there's an interest in this, I can link it.
How did you modify, do you have the source code?
Nosmo
Wow, answering to almost year old question, sorry for the delay! :)
I don't have source code, I modified the binary directly, using disassembler.
Hello SIVU,
Can you tell me please if you remember what disassembler did you used to decompile de dll file and recompile ?
« Reply #177 on: July 04, 2019, 07:19:38 AM »
Hi all,
I'm having a small issue with the plugin. Due to a problem with the motor tuning dialog not opening I had to re-install Mach3. Since then the spindle won't stop if started. regardless of a manual start or a G-code start as part of a toolpath, once the spindle starts it will not turn off. I have to hit the emergency stop. This did not happen before the re-install. There must be some setting I haven't made but I'm at a loss of where to start.
Any help would be appreciated.
« Reply #178 on: July 23, 2019, 05:43:25 AM »
No help out there? I have to press the E-stop for every tool change. That tells me that the stop command works but is not being sent in normal operation. This is really annoying.
H E L P ! ! !
« Reply #179 on: September 30, 2019, 05:53:47 PM »
Hello has anyone had an issue where the plugin can't communicate with the VFD after almost a year of working flawlessly? I came in to the machine today and the plugin could not communicate with the VFD ("unable to read value") the serial adaptor shows up in Win10 devices, The VFD works manually, the wires test positive for continuity. I haven't changed anything. I am at a bit of a loss.
