Hello Guest it is October 30, 2026, 11:13:40 AM
Author Topic: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A  (Read 318731 times)
Offline TPS
  •  2,627 2,627
Re: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A
« Reply #80 on: June 08, 2015, 01:07:12 PM »
thank's a lot Thomas !
It's no problem with the manual language = "Ich spreche auch Deutsch - Zwei Jahre in Deutschland gelebt, im Koblenz"
ok das ist gut.
Thomas
Offline slvm
  •  68 68
« Reply #81 on: June 16, 2015, 04:12:14 AM »
Hi All
Got good news and also some questions :
1-I run one test on cnc (after set the spindle only for CW rotation) it seems to be good (with one mill for hand machine and curved material, without vacuum hold )
2-I don't know why on Y the cnc made mirror (it is perhaps because I revrse Y Axis on home limit set-up) ? I revrse the Y because by Manual-Jog.
Unfortunate here can not post the short movie.
Offline TPS
  •  2,627 2,627
« Reply #82 on: June 16, 2015, 06:06:43 AM »
Hi Emil,
looks quite good so far.
--2-I don't know why on Y the cnc made mirror (it is perhaps because I revrse Y Axis on home limit set-up) ? I revrse the Y because by Manual-Jog.
X and Y have to be set like a normal coordinate system, so if we say in a rectangle
X0Y0 is the left bottom corner
X+ is going to the right side
Y+ is going upwards
allways relayed to the material.
for your spindle CCW turn.
have you tryed this pin 4   (REV)  reverse rotation -> csmio digtal output to switch CW/CCW
on the inverter for reverse run ?
Thomas
Offline slvm
  •  68 68
« Reply #83 on: June 16, 2015, 10:05:14 AM »
Regarding "spindle reverse pin 4"
I try but it seems don't work, I think the inverter is in some how pre-programmed .
Another spindle problem is the brake, when goes stop (end of part-programm the HSD motor-spindle do some strange noise and brake abrupt)
how can I can set some delay in brake ?
any way I think I solve the main problem and now is VB for ATM and drill unit.... :( + FINE TUNNING
PS give me on PM your mail to send you the movies.
I wonder what happen with Hood , ...!? How are you Hood ?
« Last Edit: June 16, 2015, 10:11:06 AM by slvm »
Offline TPS
  •  2,627 2,627
« Reply #84 on: June 17, 2015, 08:23:03 AM »
Hi Emil,
is there any posibility on this Inverter to Change Parameters,
in the Manual it does not look like there is any Display.
my email is below  the avantar.
Thomas
Offline TPS
  •  2,627 2,627
« Reply #85 on: June 17, 2015, 08:27:26 AM »
by the way,
is the spindle changing direction if you swap the analog Input wires ?
Offline slvm
  •  68 68
« Reply #86 on: June 17, 2015, 09:19:47 AM »
by the way,
When I change the reff wires the spindle change direction.
Can you help me with the tool change VB ?
Offline TPS
  •  2,627 2,627
« Reply #87 on: June 17, 2015, 10:23:33 AM »
Hi Emil,
that means you can use a gold contact relay to swap the wires to change direction.
wire this relay to a csmio output and we do some changes in M3/M4 to get this
working.
just let me know what help you need for the toolchange macro.
Thomas
Offline slvm
  •  68 68
« Reply #88 on: June 17, 2015, 11:02:23 AM »
Thomas
I use already 2 relays to change the direction but some people said is not OK to use by M4 - to +; but if you say is OK then I will do it.
By VB ATC I'm almost = 0.....First I will wire the C axis-encoder for the ATC and check the drive and the motor.
Offline TPS
  •  2,627 2,627
« Reply #89 on: June 17, 2015, 03:35:46 PM »
Hi Emil;
Thomas
maybe i missed something about this two relaiys,
pls give me a short update about this two relais.
Thomas
