Hello Guest it is October 30, 2026, 09:50:39 AM
Author Topic: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A  (Read 318676 times)
Offline slvm
  •  68 68
Re: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A
« Reply #70 on: June 07, 2015, 04:49:38 AM »
Yesterday I check the inverter, you right Thomas ,is not the same on your link, ....
I adapt 2 relay's to Csmio - Analogoutput 0 (to be able change between CW CCW), after some test the Inverter get into Alarm and block it self, so now Ihave only 2 choiche left:
-to use Analog Output (wiithout any relays) only in to the CW mode  or to change the old-inverter with new one able to be Programmed....
Offline TPS
  •  2,627 2,627
« Reply #71 on: June 07, 2015, 05:20:06 AM »
Hi Emil,
maybe you can test with pin4 (input 8) witch is in standard config for
Reverse.
make one test pin4 connected to +24VDC and
one with pin 4 not connected.
let's try and error.
Thomas
Offline slvm
  •  68 68
« Reply #72 on: June 07, 2015, 05:56:40 AM »
Hi Thomas
Here you find the connector pin from my Inverter, to have one opinion.
Also I post the Limit switches pics disposal on All Axis, the switches +/- are all in one single chain wired, so that made me problem to assign on Mach3 Inputs !? with Home switches is no problem they are separated.
Offline TPS
  •  2,627 2,627
« Reply #73 on: June 07, 2015, 06:14:26 AM »
Hi Emil,
for the axis inputs, just seperate them from the e-Stop chain.
they should be NC contacts anyway, not like in the drawing as NO contacts.
Thomas
Offline slvm
  •  68 68
« Reply #74 on: June 07, 2015, 06:55:47 AM »
You mean use the switch SWX (as example) to input on Mach as + and - Limits for X Axis ? or only for + ?
Offline TPS
  •  2,627 2,627
« Reply #75 on: June 07, 2015, 07:57:25 AM »
Yes,
user for example SWX wire it to a input and
cofigure in Port's&Pin's the same inputs fpr X+ and X-.
there is only one switch, but there should be two braket's to trigger it.
Thomas
Offline slvm
  •  68 68
« Reply #76 on: June 07, 2015, 08:20:44 AM »
got it, thanks. I will look for .
Offline TPS
  •  2,627 2,627
« Reply #77 on: June 08, 2015, 06:24:17 AM »
Hello Emil,
good news, got a manual from HSD, bad news (for you), it is in german.
but anyway, the table for connections on page 30 looks quite good,
so i made a small table for connections:
28   (REF-V) 0-10V analog input -> csmio analog output
29    (GND-A) for analog input
5   (in 5) enable inverter -> csmio digital output
4   (REV)  reverse rotation -> csmio digtal output to switch CW/CCW
8   (CM-IN) GND -> 24v GND
1   (FLT-NO) alarm relais -> csmio input inverter ready
2   (FLT-CM) for alarm relaise -> 24V+
6   (EXTFLT) external alarm -> 24V+
22   (IN3)    temperature motor (not used) ->24V+
17   (OUT3-CM) -> 24V+
16   (OUT3-NO) -> csmio input output frq. = 0 allow tool change
30   (CM-OUT) ????? -> csmio input frq. reached but it is a open collector
32   (OUT2)    ????? is connected to 24V+ does not make sence
so if only OUT2 is connected i should work with this 30/32 connection.
Thomas
Offline slvm
  •  68 68
« Reply #78 on: June 08, 2015, 09:01:43 AM »
thank's a lot Thomas !
It's no problem with the manual language = "Ich spreche auch Deutsch - Zwei Jahre in Deutschland gelebt, im Koblenz"
Offline TPS
  •  2,627 2,627
« Reply #79 on: June 08, 2015, 01:05:57 PM »
@Hood
are still watching this, to be my second chance ?
Thomas
