Hello Guest it is October 30, 2026, 10:37:37 AM
Author Topic: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A  (Read 318718 times)
Offline slvm
  •  68 68
Re: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A
« Reply #40 on: May 18, 2015, 05:36:52 AM »
Thank you folks...!
« Reply #41 on: May 18, 2015, 06:16:08 AM »
Ok just tested, you need the Serial Non Plugin chosen and also the Bit Only box.
Offline TPS
  •  2,627 2,627
« Reply #42 on: May 18, 2015, 09:22:54 AM »
tested on my -M machine.
exactly like Hood described.
Thomas
Offline slvm
  •  68 68
« Reply #43 on: May 18, 2015, 03:14:16 PM »
@Hood
@Thomas
Thank you ! IT  WORKS GREAT   :D
Offline TPS
  •  2,627 2,627
« Reply #44 on: May 18, 2015, 03:31:57 PM »
OK,
i think your B/C axis can work as a "normal" CSMIO-A axis,
so the only little problem witch is left, is to get this C/B axis
controler (Witch is now in a positionig via RS232/mode ore someting like this),
into a -/+10V mode.
Thomas
Offline slvm
  •  68 68
« Reply #45 on: May 19, 2015, 12:37:12 AM »
Yes Thomas
I intend to try to use the 6-th encoder Input for this.
But I'm afraid I must reprogramm the drive to work on -/+10V mode (configured and calibrate) , it is some kind of software Program (named winbass-from OSAI/Baumuller,I guess in fact the drives are manufactured from Baumuller but Osai just name the drives with their name)...
« Last Edit: May 19, 2015, 12:39:38 AM by slvm »
Offline TPS
  •  2,627 2,627
« Reply #46 on: May 19, 2015, 02:58:53 AM »
yes controller has to be reconfigured, but you have the others witch are running in the right mode.
had a look on my old laptop, because i have worked with Baumüller drives about 10-15 years ago.
i have a version of winbass installed, an still a install file for this software.
if you give me a serialnumber/type of the controller i can check with Baumüller weather this is the
right version to configure this drive.
Thomas
Offline slvm
  •  68 68
« Reply #47 on: May 19, 2015, 03:36:18 AM »
I got one pic with the serial number and the code tabel OSAI-BAUMULLER.
Hope this is ok for you to identify wich version I have....
I lock on the help program file but it seems I will need to have master degree on Automatization to achieve the set-up on one such drive... :-[
Thank's for info,
« Last Edit: May 19, 2015, 03:39:25 AM by slvm »
Offline TPS
  •  2,627 2,627
« Reply #48 on: May 19, 2015, 07:04:20 AM »
i am able to select your driver in my software.
i have put the software in my dropbox.
you should get a email.
Thomas
Offline slvm
  •  68 68
« Reply #49 on: May 19, 2015, 07:35:04 AM »
 8) Already got it !
thank you Thomas.
« Last Edit: May 19, 2015, 07:37:00 AM by slvm »
