Hello Guest it is October 24, 2026, 01:40:05 PM
Author Topic: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A  (Read 315405 times)
Offline TPS
  •  2,627 2,627
Re: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A
« Reply #130 on: August 10, 2019, 02:17:11 AM »
in a Standard Installation they are for example in C:\Mach3\Macros\Mach3Mill
if they are not in your profilefolder, you can copy them from there.
Offline slvm
  •  68 68
« Reply #131 on: August 12, 2019, 09:10:15 AM »
Hi
I install mach on new pc, but the result is the same the codes for coolant are not under the macros directory; if you can help me to create some codes for my CNC it is ok, if you are busy and I disturb sorry !
I need some simple macro codes for engage and disengage some outputs, that's all....
Of course for help let me reward in some how your work.
thank you in advance.
Offline TPS
  •  2,627 2,627
« Reply #132 on: August 12, 2019, 11:32:24 AM »
sorry i was wrong, there are no macro's for this Standard functions,
you only have to define the Outputs in Port's&Pins -> spindle Setup
and then in ports&pins -> Outputs your real CSMIO outputs
