Hello Guest it is October 30, 2026, 09:50:18 AM
Author Topic: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A  (Read 318670 times)
Offline slvm
  •  68 68
Re: Retrofit CNC Bulleri FPM 2813-Osai controll with CSMIO-IP-A
« Reply #30 on: May 11, 2015, 03:33:30 PM »
@Thomas
About phone I have same opinion ,and use it only for talk or read some short at morning coffe ....
@Hood
The platte is not for cooling; it is made to divide the case on 2 areas (mobo and & power supply area) and to lead the water trough and reach the reservoir on top and pump under area and lead back to radiator on top.
« Reply #31 on: May 11, 2015, 03:41:04 PM »
Ah ok I see now.
Offline TPS
  •  2,627 2,627
« Reply #32 on: May 11, 2015, 03:47:13 PM »
hate the bloody things, usualy have mine on silent ;)
yust ignore it. (don't hate it).
sometimes it is easier.
Thomas
« Reply #33 on: May 11, 2015, 03:49:29 PM »
I do, mine is usually in the car when I am not in the car ;)
Offline slvm
  •  68 68
« Reply #34 on: May 11, 2015, 04:00:03 PM »
One more question before sleep :
Any necessary set-up for the CSMIO-Modbus in the Engine Config ...Port and Pin windows ?
see attach
Thank you !
« Reply #35 on: May 11, 2015, 04:01:57 PM »
No, not for CSMIO :)
Offline slvm
  •  68 68
« Reply #36 on: May 17, 2015, 12:16:51 PM »
Hi All
Got some news:
1-I mount the machine on force power -380V
2-test and move all Axis X,Y,Z except the C for ATM, the old config of this C Axis was trough the RS 232 from the old cnc (I intend to use for this one encoder direct- need the drive one new set-up fotr this ? wait your opinion about)
for time I made all of this without to mount the csmio or Mach, is made direct from the cabinet Inputs/Outputs
3-test the Emergency Chain : mushrooms buttons, limit switches, vacuum chain, pressures, cabinet emergency switches
Unfortunate got no time to test the spindle heads & the inverter
So the point 3. From Thomas rules is not yet accomplished (hope this week to finish with the spindle and test all outputs-mean the secondary, drills , block units for 0 home on corners etc.
I will post some pics with:
Limit switches on Axis C, Z,Y,X and secondary drills location/sense of rotation.
 ??? QUESTION :
When I need to add Input from csmi-o on the Brain controls how I must to declare the csmio address ? see the attach .
« Reply #37 on: May 17, 2015, 01:29:23 PM »
What drive is used for the C Axis?
For the switch on the C it looks like it is operated via a cam, I presume that is adjustable and will likel;y be at Tool 1, this will make homing the carousel easy and it means you can just control it as an axis from Mach.
For the modbus it is as in pic below. I am not 100% certain that it is the macro modbus but fairly sure it is, would have to check tomorrow to be certain.
Offline slvm
  •  68 68
« Reply #38 on: May 18, 2015, 03:44:57 AM »
You right about ATM axis, it index the tool nr 1 at homing, the drive is on attach.
Regarding the ModBus set -up I try it , but it seems don't work....or I do somethingh wrong?
Offline TPS
  •  2,627 2,627
« Reply #39 on: May 18, 2015, 04:17:03 AM »
i'll gona try this tonight, never worked with brain.
Thomas
